Results 1 to 3 of 3
Thread: NXT Spray Wax and Gold Class Clear Coat Wax
    Apr 2005
    12
    9
    Are these two products compatable with each other?
    Can I apply the GC Clear Coat Wax and later on use the NXT Spray wax over it?
    Okanagan Valley, BC
    4,552
    386
    Hey,
    No problem! Meguiar's products are compatible with one another! In this case, the NXT Spray Wax will add a nice "pop" to the GC.
    Tim
    52
    24,964
    514
    Re: NXT Spray Wax and Gold Class Clear Coat Wax
    Originally posted by nyyanks81
    Are these two products compatible with each other?
    Getting good results with Meguiar's' spray waxes is all about technique, here's a primer on using either of our two spray waxes with some links to a couple of tutorials with pictures.
    Correctly Applying and Removing a Spray Wax
    Technique will make, or break your results, as well as a little experience learning how to apply a Meguiar's Spray Wax correctly. Check out these tutorials I wrote on using NXT Spray Wax.
    Note: The same techniques apply to using Meguiar's Quik Wax.
    In most cases, the trick to making this easy and getting good results is to apply the spray wax to an applicator, or a folded microfiber, and then use one of these items to apply the wax you your car's finish. The goal is to apply a thin coat quickly, then remove it after you have applied a thin coating to the entire car. Once you have dampened one side of whatever it is you choose to apply the spray wax with, you will find applying the spray wax goes fairly quickly and the dampened applicator helps to apply a uniform coating. Also, by spraying the spray wax onto the applicator you avoid spraying the wax into cracks, crevices and body seams.
    Using the new Even Coat Microfiber Applicator to apply NXT Spray Wax
    How to Get Great Results Using Meguiar's Spray Waxes
    Remember...
    "A little technique goes a long way"
    Spraying a Spray Wax onto the applicator instead of the body panel helps to prevent spraying wax into body seams, emblems, cracks and crevices
    Once you have dampened whatever you choose to apply the wax with, you will find applying and spreading an uniform coating over the entire car quick and easy
    After applying a thin coating and allowing it to dry to a white haze, simply remove the wax using a premium quality microfiber polishing cloth such as Meguiar's Supreme Shine Microfiber or Meguiar's Ultra Plush Super Terry Cloth Towel
  1. NXT quik spray wax-Gold class spray wax.
    By 03mach1 in forum New Product Suggestions
    Last Post: Jun 20th, 2008, 01:13 PM
  2. Does NXT spray wax work with Gold Class
    By rdv350 in forum Consumer Line
    Last Post: Nov 17th, 2006, 07:07 PM
  3. Replies: 1
    Last Post: Sep 7th, 2006, 06:55 AM
  4. Replies: 6
    Last Post: Mar 8th, 2006, 06:56 PM
  5. Gold Class Clear Coat Wax Question
    By Heiress Hilton in forum Detailing 101
    Last Post: Oct 6th, 2005, 06:39 AM
