Results 1 to 4 of 4
Thread: Tar and DA Power System Pads
  1. #1
    Registered Member
    Join Date
    Jul 2013
    Location
    Belgium
    Posts
    11
    Rep Power
    2
    Question Tar and DA Power System Pads
    Hello to all,
    I'm new in detailing, but I would like to ask you what's the difference between the pads from DA Power System [ black/yellow/red ] ?
    I can use the yellow pad for compound/polish/wax ? Of course an clean pad for each step.
    Also I would like to ask you, what can I use to remove the tar of my paint without affect the clear coat ??? I have some on my doors.
    Thank you so much.
  2. #2
    Join Date
    Oct 2004
    Location
    Pittsburgh, PA
    Age
    33
    Posts
    18,662
    Rep Power
    226
    Re: Tar and DA Power System Pads
    You could use only the yellow polishing pad if you wanted, though the black finishing pad will leave a nicer finish when waxing, and the red cutting pad will make your compounding step more aggressive if needed.
    I would check to see if TRIX or TarX is available in your area, have had good luck with those removing tar, or at least easier to wipe though.
  3. #3
    Registered Member Detailing by M's Avatar
    Join Date
    Jul 2011
    Location
    Rancho Santa Margarita Ca
    Posts
    2,197
    Rep Power
    24
    Murr has it right on the pads.
    Tar: I like Meg's body solvent but you might not find it locally. So Tarminator, WD 40 or the like.
    You need a solvent, I use "cold" solvents and not "hot" ie: Goo Gone is hot, it smells, is corrosive to your skin and will eat paint.
  4. #4
    Registered Member
    Join Date
    Jul 2013
    Location
    Belgium
    Posts
    11
    Rep Power
    2
    Thank you.
    I solve it with WD 40.
Thread Information
Users Browsing this Thread
Similar Threads
  1. DA Power System
    By Michael Stoops in forum 2013 New Products
    Last Post: Apr 6th, 2014, 03:47 AM
  2. Looking to get a DA Power System
    By OzPapaSmurf in forum The Break Room
    Last Post: Jul 8th, 2013, 01:36 PM
  3. Difference between Meguiar's DA Power System Pads
    By Tuco in forum Introduce yourself
    Last Post: Jun 14th, 2013, 05:43 PM
  4. using the new da power system
    By stang_krazy in forum Detailing 101
    Last Post: Mar 31st, 2013, 09:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
