Review: Meguiar's DA Power System
  • #16
    Re: Review: Meguiar's DA Power System
    Nice review... thanks for bumping this to the top, I missed the post in feb....
    Presently in York Pa
    2012 FLHXSE3 Black and Slate Gray
    2012 Tundra CM Black
    2015 Acura TLX White Pearl
    • #17
      Can this be used with a cordless drill? All my drills are 18v lithium ion.
      09 Ford Explorer Limited AWD
      • #18
        Thank you!
        Meguiar's recommends using a corded drill. I'm mainly assuming it's because of the needed torque for paint correction or removing defects.
        But there's nothing stopping you from trying to use it with a cordless drill. I've done it so myself but only for applying wax. Just don't be disappointed if you don't get the results you are expecting when using the cordless drill to remove swirls and defects.
        • #19
          Thank you!
          Thanks for the response, my Makita drill has pretty good specs. Bored through concrete foundation in hammer mode. I'm a newbie at this so might be good baby step away from hand waxing without the big coin of a MT300
          • #20
            Sounds like you have a powerful cordless drill. Just give it a shot and see if it works. If it bogs down when you apply pressure then it's probably because the drill is not corded.
