DA Power System -I took it for a spin
  • DA Power System -I took it for a spin
    Meguiar's DA Power System #G3500
    Introduction
    This System turns household drill into a dual action polisher. It's a very well built and thoughtfully designed tool. The first impression may not be fully convencing, but trust me, that tool delivers what it promises.
    The main purpose of this System is to create the bridge between hand work and variable speed dual action polishers. It attaches to a household drill, 3/8" chuck is recommended with speed range 1,200-2,500 rpm (max. 2,800 rpm). The package contains DA Power System tool, one 4" Soft Buff 2.0 foam polishing pad and step by step directions booklet.
    The System can be ready to use in just couple of minutes by opening its clear plastic package and attaching the tool to a drill (the tool has to go all the way into the chuck for proper and secure attachment). No experience necessary, just like with other dual action polishers, you can start compounding, polishing or waxing right away.
    Meguiar's recommends their 4" Soft Buff 2.0 (W7204) burgundy cutting pad with Ultimate Compound for compounding/ defect removal, 4" yellow polishing pad (W8204) with Ultimate Polish for polishing and 4" black finishing pad (W9204) with Ultimate Wax for waxing. Bigger buffing pads cannot be used as the backing plate is permanently attached to the tool.
    Additionally extra accessories are available for use with DA Power System: pad combos, pad/ liquid combos and carpet/ interior attachment. This System is extremely flexable.
    I used corded drill with trigger lock while testing this System.
    Waxing
    You won't feel any difference between waxing with DA Power System and any traditional dual action polisher, besides being limited to 4" pads. I was able to wax medium sized SUV (BMW X3) in just 30 minutes. I used M16 Professional Paste Wax and my experience was nothing but excellent. Furtermore 4" pads fit perfectly into most paste wax jars.
    Polishing
    The System delivers very good performance in this step. You will be able to remove light swirls/ scratches and add deep gloss in this step without any problems. The whole process, again, may take slightly more time due to smaller pad size but comparing to hand work it's gonna be more effective. Expect final results very similar to traditional dual action polishers.
    Compounding/ Defect Removal
    The System delivers good performance and good results in this step. I worked on slightly smaller areas, using 4" cutting pad, that I would normally do with bigger pads. It was mainly to concentrate on proper and effective defect removal plus to prevent compound from drying out. The same principals apply in this step: slow arm speed, down pressure, pad kept flat against surface, frequent removal of product and removed paint to prevent pad clogging. Above surface bonded contaminats should be removed by claying prior to this step as well. There are some vibrations associated with this step, which is so typical for random orbital machines, but nothing extraordinary nor escalated.
    Drills with higher speeds (closer to 2,500 rpm) would be more effective.
    Expect good tool performance in this step and removal of oxidation, scratches, water spots, etc.
    Highlights of DA Power System
    This tool is extremely easy to use. The whole set up process takes no longer than 2-3 minutes. As it is not a full replacement of traditional dual action polishers, it delivers very similar results, with polishing and waxing performance being almost identical to other machines.
    The tool works more like a dual action polisher with forced rotation, converting one-dimensional circular motion of a drill into random orbital movement, therefore it is more effective.
    DA Power System is very ergonomical. It may look like it's not so convenient to use, but after just a minute spent polishing/ waxing all these concerns go away. It offers full flexibility, including interior work.
    Its price is set much below all dual action polishers and performance much greater than all orbital buffers (aka wax spreaders). You won't be able to get similar results working by hand, it's much faster and effective.
    Final Thoughts
    I really recommend DA Power System to everybody who still did not commit to any power tools or uses orbital buffers. No more working on just 1-2 panels per day, this tool will allow to do even full paint correction in one day. It is not as fast with defect removal as rotary buffers nor larger variable speed dual action polishers but it delivers solid and effective performance much beyond hand work ability.
    Meguiar's 5-step paint care is still in effect while using DA Power System, don't forget to wash and clay your vehicle prior to use of this System.
    If you use a corded drill with trigger lock (like I did), remember that it locks in its highest speed setting, so make sure you don't exceed 2,500-2,800 rpm.
    To Come
    Testing with a cordless drill. I have Makita 18V LXT System which uses 3.0 Ah batteries. Let's see what we can achieve.
    Re: DA Power System -I took it for a spin
    Great write up Greg, thanks for taking the time to put this together as we know how much work goes into one of these posts!
      Great write up Greg & weather you have there :-(
        Great write-up Greg! You just pushed me over the edge to get one.
        I'm mainly interested in using this with a cordless drill to apply waxes. That way, I can be fully mobile and apply wax easily without a power source.
          Used it for waxing only so far, and it didnt feel like the drill was working too hard.
          Should be doable, or at least with an extra battery.
            I'm intrigued by the gearing the DA head incorporates to reduce direct rotational force to oscillation. I trust Meguiars enough to use this without fear of burn-through, but it's practical application would seem to be as a compact DA to polish smaller surfaces like door pillars, rocker panels, door sills, and other narrow trim pieces.
              Many of our friends will be very surprise with the ease of use and how good of results it delivers.
              The performance you get for the price is just named: great investment!!!
              Thanks for sharing...awesome follow up on the DA Power System.
                It's a forced rotation mechanism, so it's not terribly unlike the Flex 3401 in operation when you think about it. That means it is NOT a free rotating spindle like a G110v2 or PC so if you really press down on it the pad will continue to spin. There is a gain in cut using the smaller pads, but a loss in cut at the same time due to the slower speeds of a typical drill compared to what a full sized DA would deliver. That keeps things safe, but still allows you to remove some fairly serious defects.
                Your thoughts about the practical application really apply to current DA or even rotary users who might find a smaller tool helpful for those areas. But for someone who's always done things by hand, either because of budget concerns or they're just plain afraid of a DA buffer, this tool is a huge step up.
                  Greg great write up and pictures!!!!
                  Andy M. Moderator
                    simple....
                      Nice demo Greg. Im wondering on how many pads you used for each process on that vehicle and is there any major difference in defect removal from the soft buff 2.0 from the original pads? Any information would help me choose the right pads
                        Thank you.
                        For avarage/ medium size vehicle 2-3 each cutting and polishing pads should be okay, after you fully wash and clay a car. 1 finishing pad will let you wax a vehicle.
                        The DA Power System reduces the power of directly-driven drill plus it adds the oscillating movement. Defect removal won't be as quick as using 450-650W dual action polisher but it will be effective.
                          maybe it was just the video but it seemed like that pad was rotating VERY slowly.....
                          Zach Hall
                            Will this system work with lake country 4" spot pads as well?
                              I did a quick cleaner/waxing with 1 polsihing pad, and using 2 would have been better. Was a bit too saturated near the end.
                              And yeah, it spins pretty good.
