Results 1 to 9 of 9
Thread: carpet/upholstery cleaner
    Registered Member h_bomm's Avatar
    Mar 2012
    St. Cloud MN
    169
    3
    I was wondering which is a good quality carpet/upholstery cleaner. I need something I can spray on and work in with a towel or something and pick up with a shop vac. I've been looking at the aerosol can in the detailer line, anyone use this one and how well does it work?
    Formerly 101impala Moderator Andy M.'s Avatar
    May 2004
    Philadelphia, PA
    45
    3,956
    341
    Re: carpet/upholstery cleaner
    The Detailer Line stuff works great and you don't really need a shop vac to get it up. Work it in with a towel or a brush and get it up with another towel continually turning it until the spot is dry to the touch. Used it many times with great results.
    Andy M. Moderator
    Addicted to Detailing thoryamaha919's Avatar
    Mar 2008
    270
    8
    I have always used APC+ with great results
    It's all about the passion behind the pad whether it's a hand pad or machine pad!!
    Thoryamaha919 AKA Evan
    Mar 2012
    St. Cloud MN
    169
    3
    Andy and Evan, thanks for the quick responses! Is the APC treatment something that you would work in with a brush and then hit it with a shop vac? What is the difference going to be between APC vs APC+?
    May 2004
    Philadelphia, PA
    45
    3,956
    341
    APC + has a citrus scent. Yes you could use it to work in with a brush and vaccuum up. It also works well. I use a lot of APC and APC +. I even use it around the house for general cleaning.
    Andy M. Moderator
    Mar 2012
    St. Cloud MN
    169
    3
    Are both methods good for seats as well as carpet?
    May 2004
    Philadelphia, PA
    45
    3,956
    341
    To be totally honest I haven't used APC to clean seats or carpet. I have however used the D line cleaner quite often. The worst stain I ever got out with it was a whole cup of spilled coffee that had been dried in the baking interior during the summer. Owner didn't even blot it up when it was first spilled. I got the whole stain out. Looked brand new.
    Mike uses APC in this thread here......
    What to use on carpets and fabric seats?
    Andy M. Moderator
    32
    18,026
    219
    APC/APC+ are good for everything... if you dont have a jug, you should get one.
    The APC will foam a little more, can be handy if you need it to cling to something.. APC+ has a little degreaser in it.
    I couldnt even list the things I have used it for on the car and around the house/yard.
    Mar 2008
    270
    8
    I have used APC+ on both carpets and seats. As stated it does foam up but i use a stiff brush to work and agitate the area then vacuum the area. Sometimes if I need I will get a damp cloth and work the area. On seats it's a little more tricky cause of the foam but I just apply APC+ to a cloth then start working the area.
  1. Carpet & Upholstery Cleaner
    By Michael Stoops in forum 2013 New Products
    Last Post: Feb 19th, 2013, 03:09 PM
  2. RED WINE taken out by carpet and upholstery cleaner
    By onawrxhigh in forum Detailer Line
    Last Post: Mar 19th, 2008, 05:58 AM
  3. Problem with HD Carpet & Upholstery Cleaner...
    By LocoGT in forum Customer Service Hotline
    Last Post: Feb 28th, 2008, 11:08 PM
  4. Discontinued Carpet/Upholstery Cleaner - G9416
    By CARSGroup in forum Consumer Line
    Last Post: Jan 23rd, 2007, 02:52 PM
  5. Detailer's Carpet/Upholstery cleaner...HOME?
    By gollums_friend in forum Detailing 101
    Last Post: Jul 13th, 2006, 07:42 PM
