Results 1 to 10 of 14
Thread: Recommendation for wax
    Jul 2012
    United States
    56
    I’ve just finished the last of a tub of carnuba wax, so I need to get more wax. I’m wondering which of the ten choices here (no embedded links allowed, so here it is: http://www.meguiarsdirect.com/category/wax-protect) would be best for my car (2005 Toyota Sienna). The paint looks very good after a wash/wax—neither the clear coat nor underlying base coat are peeling, nor is there any obvious damage. I suppose my main priority here is trying to keep the paint as protected as possible, and secondarily, to keep it looking as shiny as possible. I live in the desert with a lot of sand and wind, and my cars typically lose that “just been washed” look after a couple of weeks.
    As I said, I’ve been using carnuba wax. I’m pretty sure its been about a year since I last put wax on, and it had been a few months since I washed it, but I was shocked when the water first streamed down the van, how much wax there was still on it—there was a lot of beading, an awful lot more than I expected after so long. Was this due to using a carnuba wax? Perhaps I should stick with that type of wax.
    At any rate, I also see on that page, both paste and liquid waxes. I’m not sure what the difference is—or the benefit of using one type over the other.
    1. What would be the best Meguiar’s wax to use for my van?
    2. What benefit would there be in my using liquid over paste, or vice-versa?
    32
    18,032
    219
    Re: Recommendation for wax
    Generally, a synthetic wax is most durable.
    But you tend to get a bit more durability when the surface is at its best. So things like claying, using something like Cleaner/Wax or ColorX before the regular Wax also helps.
    Or clay, then a paint cleaner (SwirlX or Ult. Polish would be mild ones), then two coats of regular wax, if you felt like that much effort.
    Just preference.
    Though paste can work well in a damp environment, but doesnt sound like an issue.
    Jul 2012
    United States
    56
    Is the Gold Class Carnuba Plus wax synthetic? It says it has "carnuba plus protective polymers" on the label itself. http://www.meguiarsdirect.com/product_detail.do?q=4622#
    Oct 2012
    Twin Cities, MN
    49
    Have you looked into the Ultimate Liquid Wax? It's synthetic, so it will last longer than your standard carnauba and doesn't stain trim. You can pick it up at any local retailer. If you're not sure about buying a full size bottle, the New Car Kit offers a small sample with other great items.
    Oct 2010
    manila, philippines
    935
    12
    GOld Class Carnauba Plus is basically a carnauba wax with some polymers to help in the durability department because without the polymers, the Carnauba wax itself may go flat sooner. Even Deep Crystal Carnauba has some polymers in it. But it's not a synthetic wax.
    Oct 2010
    manila, philippines
    935
    12
    Double post... Ultimate Wax is definitely the most durable synthetic wax from meguiars, if you do plan to get one, get the paste. Although meguiars liquid and paste waxes offer the same durability and shine, if you read up on experiences on the liquid, there have been a couple of issues with it. Nothing major really, but the paste applies more like a traditional wax, while the liquid requires just a bit of adjustment to how it is applied and removed. A big advantage the Ultimate Liquid has is that i doesn't stain trim, unlike the paste
    Jul 2012
    United States
    56
    OK the waxes I'm looking at here are priced 8, 15, and 28 bucks (Deep Crystal Carnuba, Gold Class Carnuba Plus, and Ultimate Wax). I'm wondering what the additional value in the more expensive brands are.
    Durability has been mentioned. So that means that I can go longer without waxing if I buy the more expensive kinds?
    32
    18,032
    219
    I would tend to say follow the same schedule, but get better protection during that time.
    As mentioned above, the New Car Kit is a great way to get a sample of the Ult. Wax.
    Another good way to keep things protected (and get some longer life) is to use a spray wax like the Ult. Quick Wax or Gold Class Spray Wax after future washes.
    Jul 2012
    amhersburg, ontario
    22
    i strongly recommend the ultimate wax, some of the additional cost is due to the package including a foam applicator and a black microfiber towel.
    i stand by ultimate wax, extreme durability and is very safe to use, easy to use in liquid too, i have personaly never had rouble removing it... to avoid that problem entirely, start with a small amount... or use the ultimate detailing cloth to remove, works excellent.
    if you really like the look of your carnauba then use both, just be sure to put the synthetic down first. then you will get the best protection, depth and shine, especially with dark vehicles.
    Murr1525 has excellent advice aswell, the cleaner the surface the better the protection.
    Nov 2009
    Stang Island, NY
    453
    8
    UPW gets my vote!
  1. product recommendation.
    By gerson200 in forum Consumer Line
    Last Post: May 1st, 2012, 11:50 AM
  2. Looking for recommendation
    By Saab in forum Detailing 101
    Last Post: Apr 16th, 2010, 03:08 PM
  3. What's Your Recommendation?
    By Civic Man in forum Detailing 101
    Last Post: Feb 27th, 2009, 03:30 PM
  4. Clay Bar Recommendation
    By bradipock in forum Detailing 101
    Last Post: Jan 6th, 2009, 08:53 PM
  5. Need your Recommendation
    By LiveWire in forum Detailing 101
    Last Post: Jul 6th, 2004, 10:23 AM
