Results 1 to 10 of 20
Thread: DA Microfiber system. Cleaning pads with" dust off" style can of compressed air???
    Jun 2012
    San Fernando Valley, CA
    7
    Right now, I use a brush to clean the DA mircofiber pads between passes. The other day I thought about using one of those cans of computer/electronics compressed air dusters since I have a few in the house. Good or bad idea?
    Should I be concerned about the propellant contaminating the pad or product?
    Jul 2011
    45
    1,176
    You can uae those with no problem.
    But a brush works fine, why waste money on those?
    I use a brush like you do but I clean them with a pad cleanner when they get to clogged, let that one dry and grab a new pad. I use like 3-5 pads on one job
    Trabuco Canyon, CA
    15,666
    1073
    Re: DA Microfiber system. Cleaning pads with" dust off" style can of compressed air?
    You shouldn't worry about the propellant contaminating the pads, but you might want to worry about the cost of doing this on a regular basis. If you've just got some cans of air laying around and you're looking for a good use for them, go ahead and give it a shot (just make sure you don't freeze product onto the pad and start buffing with it!). Otherwise, Mario's suggestion of using a pad washer is a good one. If you're doing this for a living it makes a lot of sense to have a pad washer in your arsenal, but for the casual enthusiast it might not, just because of the cost of the unit. We'll leave the money decision to you, though!
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Registered Member jarred767's Avatar
    Jan 2007
    Seattle, WA
    29
    229
    9
    I use a pad brush right now too, and it seems to the job well and cheaper in the long run that those cans of air. Since I'm mobile I don't have a compressor just lying around in my truck, so this works. However I detailed my own car with this system the other day and used my compressor at home and it seemed to work a little better. I've thought about getting a small one to put in my truck, but curious how much pressure is necessary to really do the job (this would be the only use for the compressor). Anyone have any ideas on minimum amount of pressure needed or a good small compressor model that would be easily transportable?
    Jarred
    Dynamic Mobile Detailing
    http://www.dynamicmobiledetailing.com
    Doors of opportunity don't open, they unlock; it is up to you to turn the knob.
    Jun 2012
    Columbus ohio
    33
    I bought the Canless Air Systems O2 Hurricane for use with my MF pads. Only requires batteries. Cleans as well as using shop air at work. Expensive at $80 but no compressor, hose, blow gun or generator needed. Perfect for mobile detailers or hobbyist detailing. Bought mine from Newegg.
    Jan 2007
    Seattle, WA
    29
    229
    9
    Very interesting concept, I looked it up and it sounds good. Amazon has a version of the same product from CANless that doesn't require batteries, just recharge it. It would definitely save space for other stuff and if it works just as good, it could be good option. I'm gonna do a little more research, but it sounds like a potential winner. Thanks for the recommendation.
    And it really works just as well as a compressor?? I guess it does say that it blows air at speeds of 140mph.
    Jarred
    Registered Member s word's Avatar
    Jul 2012
    west covina
    246
    3
    Wow this looks like a good solution. Between the purchasing of the brushes and the other savings and uses this brings. This would seem to be a good deal for the $$$. It is priced near cheap compressors but the mobility this brings would have more uses than a compressor. Now only if it could pump up car tires too.
    Nov 2010
    Vancouver
    898
    I'm not sure canned air or this air system will clean pads as well as a pad washer....the Megs pad washer has a gamma lid so it's pretty portable.
    I have 2 of the Meguiars pad washers...one for polishing pads and one for finishing/waxing pads
    "STRIFE" aka Phil
    2003 Mazda MPV LX (Metalic Green) (wifey's)
    Jan 2007
    Seattle, WA
    29
    229
    9
    I am thinking of using it more for on-the-fly cleaning instead of a compressor or brush. The pad washer is for more deep cleaning, not on-the-fly cleaning, correct?
    Jarred
    Nov 2010
    Vancouver
    898
    I think compressed air would be good for fluffing up the MF fibers after working on each panel...i guess everyone has their preferances?
    "STRIFE" aka Phil
  1. Replies: 7
    Last Post: May 1st, 2012, 08:15 AM
  2. a Megs car soaps "cleaning power" ... Mythbusters style!
    By fredcandetail in forum Professional Line
    Last Post: Apr 30th, 2011, 05:36 PM
  3. DA Microfiber system, 5" or 6" pads when used with PC 7424?
    By gbackus in forum Professional Line
    Last Post: Apr 20th, 2011, 01:50 PM
  4. SURBUF pads vs "new" MF DA system.... OMG!
    Last Post: Mar 8th, 2011, 12:10 PM
  5. Cleaning pads "on-the-fly"
    By EPHIOS in forum The Dual Action Polisher
    Last Post: Oct 20th, 2010, 04:22 PM
