Results 1 to 10 of 11
Thread: products to buff finish using rustoleum specialty laquer
    Sep 2012
    Glendale, CA
    16
    I am in the process of finishing a speaker i made for my stereo.
    I first skim coated the speaker using usc proflex putty and sanded it down using 400 grit
    I next applied rustoleum high build primer and sanded using 400 grit once again. I will be adding about 6-8 coats of gloss black specialty laquer, followed by the same brand laquer but clear coat.
    I plan on wet sanding the clear up to 2000 or 3000 grit paper
    I wanted to find out what products i should use to buff the final clear coat
    I will be working by hand
    Thanks
    Jul 2011
    45
    1,192
    Re: products to buff finish using rustoleum specialty laquer
    If your Clear coating it you don't need that much base coat. the base coat is just the color and painting it 6 times isn't going to improve the color. but paint away if you'd like.
    the CC is the important part. that is the part that is going to orange peel and that's what your going to sand. so put a nice layer of CC.
    So with that being said I would wet sand it to get it flat then buff out the WS marks and wax. and trying to get rid of WS marks by hand sounds annoying to me. you need some power tools to do it right, imo.
    Sep 2012
    Glendale, CA
    16
    Thanks for the reply
    Should i sand between the color coats?
    Should i sand the final color coat before i apply the clear?
    Thanks agaim
    Jul 2011
    45
    1,192
    only for adhesion. it's not going to improve the over all reflective quality of the final top coat.
    you can sand if you want, it might help it might not.
    the top coat is what your going to need to concentrate on. that it the one that is going to need to be as flat as possible, to reflect the most amount of light.
    <--- note my avatar. that is what your going to do to the WS marks
    oh yea products, I mostly use the Detailer line so I myself would use M105,M205 and M20. You'll have an easier time finding Ultimate Compound, Scratch X and NXT. I don't use those products but all the enthusiast here love them so I can recommend them.
    Trabuco Canyon, CA
    15,709
    1074
    For buffing out sanding marks by hand, stick with M105/M205 but stay away from any sort of terry cloth applicator. Use a foam wax applicator pad, and ease up on the pressure when finishing the M105 application. Use just light to moderate pressure when using the M205 with a fresh pad.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Sep 2012
    Glendale, CA
    16
    What kind of cloth should i use to remove the product?
    Jul 2011
    45
    1,192
    Micro Fiber.
    Sep 2012
    Glendale, CA
    16
    Thank u
    Sep 2012
    Glendale, CA
    16
    any idea on why I do not have permission to post pics?
    Sep 2012
    Glendale, CA
    16
    On this test piece i used rustoleum gloss black specialty lacquer about 4 coats, followed by the same brand lacquer but clear coat about 6 coats.
    I am using spray cans since this is a onetime thing.
    After i sprayed the clear I wet sanded lightly with 1500 grit, and followed that with meguires ultimate compound, and then ultimate polish.
    I am using old micro fiber rags to take the compound and polish off and have been using a pad to apply it, not sure what kind of pad it is. I will be ordering meguires pads and new micro fiber cloths for when i am ready to buff the actual speaker.
    The test piece looks good in normal light like in a room but if I put it by the window in direct sunlight and angle it a certain way I can see a lot of scratches.
    A few questions I have
    1) I allowed the paint to dry about 3 weeks, even after 3 weeks I am still able to put a nail print in the paint using my thumb? Does this mean it needed more time or is lacquer that soft?
    2) I do have an attachment for my drill which allows me to attach a 4” pad, would this be of any help or more harm than good?
    3) Any other input would be appreciated
    Here is a link to flickr for pics since I am unable to upload.
    http://www.flickr.com/photos/87725282@N06/
  1. FS: Meguiar's Fast Finish No-Buff Wax
  2. Finish too good for non-streaking products?
    By pcmark in forum Detailing 101
    Last Post: Apr 29th, 2008, 06:42 PM
  3. Wax For Laquer Paint
    By George in forum Introduce yourself
    Last Post: Nov 25th, 2006, 05:09 AM
  4. Finish Kare products
    By F-150 in forum Detailing 101
    Last Post: Mar 23rd, 2006, 07:23 PM
  5. PPG Specialty by Meguiars
    By showtime in forum Detailing 101
    Last Post: Aug 26th, 2005, 01:00 PM
