Need help with gum
  • Need help with gum
    Looking for suggestions to remove gum from the painted underside a car's exterior.
    TIA
    I'm crafty, but not good at crafts.
    Re: Need help with gum
    I would try a pressure washer, and if that doesn't work, try freezing the gum and breaking it off, or shattering it.
      I'll try some ice cubes to freeze then remove. Thanks!!
        If those don't get the gum cold enough, you could try dry ice or try compressed air. Shake the can, then turn it upside down, using the straw to guide the very cold liquid to the gum.
        The cans go for 5-8 dollars or so and can be used for many things. Here is a picture.
          Dynamic Detailing
          541.668.0480
            http://www.walmart.com/ip/Innovera-C...ndingMethod=rr
            Even better. Yeah, I have some I use to blow out electronics and stuff.
            Thanks.
              goofoff, tar remover, body solvent, orange cleaner, actull gum remover, check your local janatorial supply store.
              DetailingByM.com
                Brake cleaner does wonders. I use the noncloronated one on gum and paint transfers also.
