Hello everyone,
Has anyone experimented with this paint?
I work by hand and I want to start doing Polishing and I'm quite confused: (
What kind should I buy?
Thanks everyone hope you help me!
Hello everyone,
help?
Have you picked up any products so far, or starting fresh?
I havent worked on it, so it would just be general advice from me. But claying, a mild cleaner/polish like Ultimate Polish and a wax of your choice wont hurt anything. I dont know if you had to fix defects.
can i use clay, uc then wax or allso need polish ?
Do you have swirls, etc that need fixed up with the UC (Ult. Compound).
If not, the Ult. Polish would handle mild cleaning and the polishing oils.
You can use any of our products on this paint, but it tends to be very scratch sensitive paint and can be sort of a pain to work on. Using high quality applicators and towels is every bit as important as which liquids you select, and you should start fairly easy if working by hand as it's very easy to create pressure points with your fingers that will mar the surface.
(800) 854-8073 xt 3875
mstoops@meguiars.com
Please post technical questions directly to the forum rather than emailing or PM-ing me. You will get a faster response on the forum, and your question could help someone else, too!
try a very small 2X2 area anywhere on the car and if it looks good do the rest. Detailing is mostly a trial and error processes. Don't be afraid, just use the microfiber pad softly and if that doesn't work, try again a little bit harder. Keep trying it to help you see how hard you will have to press before you get some results. Keep your fingers flat as possible and close to each other so you don't leave marrs on the car.
What condition is the paint in now? As noted above, if there are no scratches/swirls, you may not need it anyway.
there are some ... and even Three points on the hood
i thinks its might be a start of clear coat failure. no matter how hard i try its not coming off!
pic: http://imageshack.us/photo/my-images/692/img04741.jpg/
