Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: QD + Scratchx = Paint Discoloration
    Sep 2012
    Toronto
    Unhappy QD + Scratchx = Paint Discoloration
    Hey Guys,
    I've read over numerous posts on using ScratchX to remove light scratches so i finally decided to use the product yesterday on a light 1" long scratch on my bumper. I'm working on an '11 lexus IS w/ white paint. I washed the area with Meg's Gold wash, used Megs Ultimate Quik Detailer then proceeded to use ScratchX with Megs foam applicator pad. I applied light pressure the first try, followed by two more applications of medium pressure with each application being 10-15 secs. After the last application, i started seeing a very light green haze surrounding the scratch i tried to remove. Although the scratch did get lighter and less visible, i now have this light green haze that can be seen when you look at the area at different angles up close.
    Any ideas on what caused this and how to fix it??? All i used was a blue MF towel + foam applicator pad with the Megs products.
    Please help!!!
    Dec 2009
    Iowa
    2,309
    30
    Re: QD + Scratchx = Paint Discoloration
    In my experience, Lexus paint is very delicate. From your description, it seems unlikely you've gone through the clear coat and base coat. It also seems unlikely that Ultimate Quik Detailer and ScratchX would tint the clear coat.
    When you rub the end of your fingernail over the scratch can you feel it? The area you worked on is it all green or limited to the center? Would you be able to take a photo and post it for some of the experts here to review? Thanks.
    David
    32
    18,108
    220
    Dont usually get color transfer from pads/towels.. applicator want green?
    Registered Member gsaintchar's Avatar
    Aug 2012
    Indianapolis, IN
    52
    This sounds like color transfer from the towel. I'm gonna guess that the towel is new and has never been washed, or only washed a few times. I would use a foam pad and Ultimate Compound, it is good for really cleaning the surface from defects and oxidation, in your case stain. No need to rub real hard, I would say light too medium pressure with slow circular motions. This may take a few passes, but the sooner you do it, I think the better results.
    Wipe off each pass with a WHITE towel. Let us know how it's coming.
    Sep 2012
    Toronto
    I tried taking pictures but the green haze is so light that you can only see it at different angles... When I rubbed the end of my fingernail on it I don't feel the scratch, the entire area that I rubbed the qd and scratchx has that green haze... I'd say a 1" diameter circle. The megs foam applicator that I used was purple, didn't notice anything on it except the scratchx formula which was white..
    Does qd and scratchx cause discoloration? From experience has it happened before?
    Not sure if I should go through another application of scratchx in an attempt to remove it.. advice?
    Thanks for the help!
    Aug 2012
    Indianapolis, IN
    52
    If you can't get hold of Ultimate Compound tonight, try using the ScratchX lightly on just one corner of the area that is green, however, you need to change the foam applicator to one that has been frequently used or a different color, change towels to white. If this works, then finish the entire area.
    Aug 2012
    Indianapolis, IN
    52
    If the haze is that light, Ultimate Polish may work too. When using any of these products, it is imporant too make sure you are rubbing it in until it looks almost completely dissolved, wipe off and proceed with the next pass.
    Sep 2012
    Toronto
    Hmm.. Since scratchX is a little less aggressive than the ultimate compound would that be ok to use?
    I'll be planning on:
    1) Wash area with megs gold wash w/ mf wash mitt
    2) Scratchx w/ foam applicator
    Will prob try tomorrow cause it's dark out...
    Sep 2012
    Toronto
    Thanks will give it a shot, I'll update tmrw!
    Aug 2012
    Indianapolis, IN
    52
    Quote Originally Posted by avrxxx View Post
    Yes, remember you are not going to be real aggressive when working with it. Light rubbing, let the compound do the work.
  1. ScratchX 2.0 on new paint
    By Nutter in forum Wet-Sanding, Color Sanding, Rock Chip Repair
    Last Post: Aug 27th, 2010, 04:36 PM
  2. Paint Discoloration HELP!!!
    By Phatty McPatty in forum Detailing 101
    Last Post: Jul 20th, 2009, 09:11 PM
  3. Replies: 2
    Last Post: Jun 3rd, 2009, 04:16 PM
  4. ScratchX 2.0 - Removing Too Much Paint?
    By markymo01 in forum Detailing 101
    Last Post: Nov 15th, 2008, 10:14 AM
  5. Can I use ScratchX as a paint cleaner?
    By Bakesalee in forum Consumer Line
    Last Post: Jul 17th, 2008, 07:27 AM
