Results 1 to 4 of 4
Thread: why is my foam polishing pad heating up?
    Oct 2008
    USA
    59
    5
    hey guys this weekend i was buffing a friends car and well i was using a soft buff 2.0 pad with M80 on my g110v2 and i was using it for a couple hrs stopping here and there, then all of a sudden i started to notice the center of the pad was starting to heat up. The machine was staying perfectly cool and gave me no problems, then just toward the end of the detail the pad just got hot and hot, so i would let it cool off then continue. could this be because the pad was getting clogged? or i was using too much pressure? idk ive never had this problem before. this pad has been used about 3 times to do full car details. i tried to clean it so often with a microfiber over the pad then turning on the machine. Just wanna get some opinions why this was happening, thanks
    Registered Member RPPM's Avatar
    Jul 2010
    46
    387
    6
    Re: why is my foam polishing pad heating up?
    My guess is build up of product soaking into the pad. This causes the heat build up, and will lead to pad failure. Might want to use more than one pad for corrections. I usually use 3 pads for paint correction/polishing.
    Trabuco Canyon, CA
    15,724
    1074
    Heat build up on a pad when used on a DA tends to concentrate toward the center of the pad, and product will collect more in the center of the pad as well. For comparison sake, on a rotary the heat will tend to build up more toward the outer edge of the pad.
    If you used just a single pad for the entire vehicle, and you had to get fairly aggressive with it (pressure, speed, combo of the two) it will get warm over time. Keeping it clean is a good idea, of course, but as RPPM points out it's not a bad idea at all to swap to a fresh pad during the course of a full detailing session. When cleaning, using a terry cloth towel rather than microfiber will likely pull more product out of the pad, helping to further reduce that build up of both product and heat.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Oct 2008
    USA
    59
    5
    thanks guys i appreciate the responses !
  1. Replies: 4
    Last Post: Jul 16th, 2012, 12:40 PM
  2. Foam polishing pads...
    By daniel clark in forum Detailing 101
    Last Post: Sep 29th, 2011, 06:07 PM
  3. W8207 - Washable Foam Polishing Pad
    By Mike Phillips in forum Professional Line
    Last Post: Nov 3rd, 2008, 03:21 PM
  4. What are you paying for home heating oil.
    By jayharold in forum The Break Room
    Last Post: Apr 6th, 2008, 05:34 AM
  5. OUCH!!! Just got my home heating bill...
    By kellyinkc in forum The Break Room
    Last Post: Jan 2nd, 2006, 03:58 PM
