Results 1 to 3 of 3
Thread: help with damp sanding clear
  1. #1
    Registered Member
    Join Date
    Jul 2012
    Location
    Tri-Cities, WA
    Posts
    5
    Rep Power
    1
    I have started damp sanding my 2 week old clear. I first damp sand it flat with the megs backing pad and the megs interface pad with the 1500 sanding discs.
    I then switch to megs 3000 grit finishing discs and damp sand. It then cut and buffs like a dream and looks great.
    However if you look very close with your eye 10" away you can see thousands of light half moon sanding scatches.
    Should I try using the 3000 grit finishing discs without the interface pad? ie.. attach the 3000 finishing disc directly to the backing pad?
    Any other ideas?
  2. #2
    Addicted to Detailing thoryamaha919's Avatar
    Join Date
    Mar 2008
    Location
    Pittsburgh, PA
    Posts
    314
    Rep Power
    9
    Re: help with damp sanding clear
    Quote Originally Posted by adrynalinjunkie View Post
    Are you able to take a photo of this?
  3. #3
    Registered Member scapegoat's Avatar
    Join Date
    Aug 2011
    Location
    Pa.
    Posts
    46
    Rep Power
    2
    What yiu are seeing is the sanding marks keft behind from the 1500 more likely then the 3000. If you have enough clear coat on the vehicle I would go over it again with the 3000. Or you use a coarser or more abrasive compound with a wool pad , followed up with black foam pad and u/p .
Thread Information
Users Browsing this Thread
Similar Threads
  1. Wet sanding / polishing clear coat
    By davemel3nzc in forum Detailing 101
    Last Post: Mar 18th, 2011, 08:41 AM
  2. damp sanding with da polisher
    By elohel in forum Wet-Sanding, Color Sanding, Rock Chip Repair
    Last Post: Oct 27th, 2010, 11:37 AM
  3. Clear Coat Sanding
    By gcornett in forum Detailing 101
    Last Post: Sep 11th, 2010, 05:11 AM
  4. Damp-Sanding a 1956 Chevrolet Belair with Meguiar's Unigrit Foam Finishing Discs
    By Mike Phillips in forum Wet-Sanding, Color Sanding, Rock Chip Repair
    Last Post: May 24th, 2010, 05:06 AM
  5. how much clear to lay down and how long to wait before wet sanding?
    By hirevn in forum Wet-Sanding, Color Sanding, Rock Chip Repair
    Last Post: May 21st, 2005, 05:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
