I have started damp sanding my 2 week old clear. I first damp sand it flat with the megs backing pad and the megs interface pad with the 1500 sanding discs.
I then switch to megs 3000 grit finishing discs and damp sand. It then cut and buffs like a dream and looks great.
However if you look very close with your eye 10" away you can see thousands of light half moon sanding scatches.
Should I try using the 3000 grit finishing discs without the interface pad? ie.. attach the 3000 finishing disc directly to the backing pad?
Any other ideas?
