Results 1 to 9 of 9
Thread: How to properly apply 2 layers of wax?
  1. #1
    Registered Member
    Join Date
    Aug 2012
    Location
    USA
    Posts
    4
    Rep Power
    1
    First time detailer here (did my first 5 step a few days ago) and I have a question regarding waxing.
    I know Meguiar's recommends 2 layers of wax (I'm using ULW). However, how do we do this properly? Do we apply once, let dry, remove, then apply next layer?
    Additionally, due to time constraints and me needing the car, I drove it after only 1 layer. If I wanted to add another layer, how would I go about doing that? Hose down, dry, then apply ULW (or would drying with microfiber remove the first layer of wax?) Or would using Quick Detailer spray, followed by ULW work?
    I'd imagine just waxing now is a bad idea, considering it's been outside and probably contaminated and will scratch the car prior to any cleaning.
  2. #2
    Registered Member ChevyNick's Avatar
    Join Date
    Sep 2011
    Location
    Michigan
    Posts
    414
    Rep Power
    6
    So after you lay down the first layer, wait about 24hours or something, and apply a second layer. If your car was used within the 24 hour time period but wasn't rained on or anything, a simple wipe down with Ultimate Quick Detailer would be safe to do. After the wipe down, you would apply the second coat.
    Little clarification added here as I see now you had a few questions.
    When applying the first layer, let it dry to a haze so when you wipe a finger on the wax on the paint, it doesn't smear which means the wax is dry and ready to be removed. Do this again a day later.
    Always searching for the best.... Keep it country!
    SkiDoo Snowmobiles!
  3. #3
    Registered Member
    Join Date
    Aug 2012
    Location
    USA
    Posts
    4
    Rep Power
    1
    Re: How to properly apply 2 layers of wax?
    Is the 24 hours necessary for all waxes or is that just the curing period for some waxes?
    If I understand correctly, despite being a synthetic polymer, Ultimate Liquid Wax doesn't require a curing time and can be wiped off prior to a swipe test (about 5 minutes). Does that mean they can be layered after drying, or is waiting a day still neccessary?
  4. #4
    Registered Member ffboy's Avatar
    Join Date
    Oct 2010
    Location
    manila, philippines
    Posts
    935
    Rep Power
    12
    Quote Originally Posted by CedarZ4 View Post
    Cure time is different to haze time. Normally, you apply a wax wait for it to haze maybe 5-15 minutes, depending on humidity and temperature, then remove the hazed wax. Cure time is different. After removing the polymer or synthetic sealant, you wait for 12-24 hours before putting another coat of sealant. This is because synthetic sealants (well, most of them anyway) require this period to allow the polymers to cross-link with the paint and fully bond to the paint. Traditional waxes normally don't require this cure time, normally this applies to synthetic sealants
  5. #5
    Join Date
    Oct 2004
    Location
    Pittsburgh, PA
    Age
    32
    Posts
    18,034
    Rep Power
    219
    24 hours is best. 30 minutes or so at least is nice, but not like the wax will all fall off if you dont do 24 hours.
  6. #6
    A proud Meguiar's Detailer! Please Wash Me Detailing's Avatar
    Join Date
    Jul 2011
    Location
    Rancho Santa Margarita ca 92688
    Age
    45
    Posts
    1,202
    Rep Power
    14
    Why are you doing this?
    to me it's just a waste of time and product.
    It's already be proven that layering is a myth and in some cases there is less wax left on the paint the more you wax it.
    imo, pick a wax you like that gives you the results the first time you apply it.
  7. #7
    Administrator Michael Stoops's Avatar
    Join Date
    Oct 2004
    Location
    Trabuco Canyon, CA
    Posts
    15,724
    Rep Power
    1074
    We do recommend two thin layers, just to ensure uniform coverage and appearance. When properly applied (ie, very thin) it can be difficult to see just where you've applied the wax, especially on lighter colors. With experience though it actually becomes much easier to tell where you've applied and maybe where you've missed a spot. So..... apply the wax/sealant, let it dry, wipe off the haze, then apply again, let dry, wipe off the haze. Ideally, when using a synthetic sealant, a 12-24 cure time is a good idea but it's not always practical to do this. Doing a second application of a synthetic sooner isn't going to cause a problem, and it's highly doubtful that anyone would ever be able to visually distinguish whether you'd waited an hour or a day between applications.
    Obviously you want a clean surface when applying wax. If you just drove the car one day and the weather was nice, a careful wipe down with a quick detailer and a few microfiber towels should properly clean the surface of any loose contaminants so that you can apply wax to it. If you drove for a few days and you picked up a lot of fall out, then a proper wash is probably best. As long as you're using a quality car wash you won't strip off the first application.
    Spot on. Clean the surface - QD, wash, whatever it needs based on its current state.
    Mario is right about the actual layering of waxes and sealants so don't expect an ever increasing level of gloss, protection, whatever if you use several applications. Sure, we could probably sell you more wax if we supported that process, but it just doesn't work that way.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Please post technical questions directly to the forum rather than emailing or PM-ing me. You
    will get a faster response on the forum, and your question could help someone else, too!
  8. #8
    Registered Member
    Join Date
    May 2004
    Posts
    840
    Rep Power
    18
    I used to apply 2 layers as well. Then I realized that it was probably not necessary for me. I wax often, like once every 3 weeks or so. The sole purpose of 2nd layer is even coverage and it will not improve the protection. As for appearance wise, it will not make a difference for light color vehicles.
    For people who wax every 3 months, the 2nd layer is a must.
  9. #9
    Join Date
    Oct 2010
    Location
    manila, philippines
    Posts
    935
    Rep Power
    12
    Applying a 2nd coat of wax is more psychological than for adding gloss or extra protection, and also has become my habit. I put real thin coats anyway, so I'm not really wasting product.
Thread Information
Users Browsing this Thread
Similar Threads
  1. How to apply properly apply compound?
    By sunfire in forum Detailing 101
    Last Post: Nov 21st, 2008, 08:14 AM
  2. 2 layers of #21 or #21 with NXT?
    By Mless5 in forum Detailing 101
    Last Post: Mar 25th, 2007, 04:54 AM
  3. Layers of Wax
    By LT22 in forum Detailing 101
    Last Post: Sep 16th, 2005, 08:12 AM
  4. How to apply #83 properly with PC?
    By Marc08EX in forum Detailing 101
    Last Post: Aug 29th, 2004, 07:52 PM
  5. How many layers...
    By vwguy in forum Consumer Line
    Last Post: Jun 19th, 2004, 04:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
