Results 1 to 10 of 14
Thread: Is this paint saveable ? 2000 Miata red hardtop . .
    Aug 2010
    LA MIRADA
    3
    Is this paint saveable? I have tried using hand applied Ultimate Compound on a test spot but it just soaked it up in a minute or 2. I have a dual action polisher.. Any suggestions?
    Mar 2012
    Central, AR
    133
    3
    Re: Is this paint saveable ? 2000 Miata red hardtop . .
    You might apply a coat of Ultimate Polish with the DA. This will add some oil's to the dry paint. Then, apply a coat of Ultimate Compound with your DA. Ensure it is done on a cool surface and in the shade. Only work it for a few minutes and then remove with a MF towel.
    James
    32
    18,002
    219
    Did your applicator turn red at all?
    Aug 2010
    LA MIRADA
    3
    Yes when I tried it with hand application...I will be trying the previous tech. in a few minutes
    Registered Member CHzo6's Avatar
    Mar 2004
    Maine
    477
    14
    You need to get some #7 show car glaze and really let it soak in. Lots of good write-ups on here about using it.
    32
    18,002
    219
    Yeah, I would want to try and get a product with a lot of oils on there first.
    A pure polish like Deep Crystal or #7 would be good.
    Or a cleaner polish like #80 or Ult. Polish.
    Jun 2010
    412
    8
    This article deals with restoration of older single-stage paint:http://www.autotraderclassics.com/ca...sationId=21363
    Since your Mazda is actually newer paint technology you may not benefit as much from the force-feeding of M07 into the paint as older finishes do. However, you will very likely benefit from the use of an oil-rich product to moisturize your apparently parched paint, even if you do any serious compounding after, I'd recommend trying M80, using as aggressive of a pad as you have available. If you test spot achieves the desired results, but leaves swirls behind due to the pad, you can always repeat the procedure the using the same product with less-aggressive pad.
    Bill
    Trabuco Canyon, CA
    15,666
    1073
    That's some seriously dried out paint you're playing with, but since it's single stage (even though it's a more modern single stage) it's going to benefit from something a bit more oil rich - either M07 or even M80.
    The pic below is a '64 Chevy wagon that was recently in our garage for a couple of TNOG sessions. If we could bring back this nasty old paint, you should be able to do the same with this Miata roof.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Jun 2010
    412
    8
    Too bad you live so far away. I'd enjoy playing with some test spots on your Mazda, just to see if what I've learned on older single-stage paint restoration works on the later models. The only thing I've done anywhere close to your Miata was an early 90's red Toyota Celica about 10 years ago. . I used M03 by machine and it worked pretty well, but I felt something with a bit more cut would have been much quicker and more effective. I didn't even know about M80 at the time, nor did I know that M07 was so effective as a first-step product, before you did any buffing. Please keep us posted on your progress, good or not so good.
    Bill
    Aug 2010
    LA MIRADA
    3
    Here it is .....It looks good from 5 feet away but when 9-10 inches away I still see many small fine scratches. Most came off but about 30 percent are still there. I used 2 coats of #7 allowing it to soak in for about 20 minutes for each heavy coat. I then followed with a D.A polisher Ultimate Compound with red pad.
  1. 2000 BMW (Total Paint Correction)
    By chethewitt in forum Extreme Makeover Before & After Pictures
    Last Post: Dec 5th, 2011, 02:32 PM
  2. Jeep Hardtop
    By crlohn in forum Detailing 101
    Last Post: Feb 16th, 2010, 06:17 PM
  3. Presidential Detailed: 2000 Honda S2000- PAINT RESTORATION
    By Presidential_Detail in forum Show Off Your Latest Detail Work
    Last Post: Jan 28th, 2009, 08:26 PM
  4. White Paint on 2000 Toyota 4 Runner
    By foosorlose in forum Detailing 101
    Last Post: Apr 16th, 2008, 11:13 AM
  5. What type paint? (1991 Mazda Miata)
    By amg/md in forum Detailing 101
    Last Post: Nov 21st, 2005, 09:09 AM
