Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: How do I remove polish and wax stuck in all the chips and scratches?
    Aug 2012
    Western Australia
    Hi everyone I had recently done a prep,cut and wax on my car to help with the many fine scratches on it.This had of course helped with the fine scratches however another problem then arose that because there was so many scratches and chips the polish and wax got stuck in them and turned white. This would not be a problem if my car where in fact white, unfortunately it is black so it has made my car look much worse than what it did originally. Is there any way to solve this apart from a full respray? I have tryed high pressure hose to blast it out, got little toothpicks soaked in methylated spirits to pluck it out which did not work because there were very small chips that it had went into. Is there any other options which I should try?
    May 2011
    Australia
    93
    3
    Re: How do I remove polish and wax stuck in all the chips and scratches?
    Hey mate, good to see another Aussie on here. What products were you using? I have the same problem with certain polishes and waxes drying white in the stone chips on the front of my dark blue car.
    I have since stopped using NXT on the bonnet and have begun to use #26 Hi Tech Yellow Wax, and NXT 2.0 on the rest of the car. #26 dries clear and so is not noticeable in the stone chips. My prep stage is almost always the same, clay and Ultimate Polish. The polish does not leave white residue, but others do (I know Colorx definetely does).
    I suggest going over the chipped parts with UP to clean out the old stuff, and then reapplying #26.
    EDIT: I use the paste version of #26.
    Jul 2012
    Fairborn Ohio
    16
    i would imagine that claying that area very carefully would work. it may, however the wax from where you want it,as well.
    Registered Member BINGO53's Avatar
    Dec 2007
    Pasadena, Texas
    98
    6
    Try a toothbrush and regular Quick Detailer (maroon bottle) I use a "detailing brush" shaped like a toothbrush, it has stiffer bristles and is wedged. This may not remove all of the excess wax, but will put enough of a dent in it that the rest will eventually come out with subsequent washes.
    Respectfully submitted,
    BINGO53
    Aug 2012
    Western Australia
    Isn't the Clay bar designed to remove contaminants from the surface though and not the paint chips and crevices though. Because that was my original plan but it was pointed out to me that this would not work.
    Dec 2007
    Pasadena, Texas
    98
    6
    Quote Originally Posted by ve1 View Post
    Isn't the Clay bar designed to remove contaminants from the surface ...
    That is completely correct.
    Clay will only remove the stuff stuck to the TOP of the paint. In my case, oak sap and aphid poop.
    Dried wax can only be carefully "scratched at" , or picked at when its down into a crevice.
    Aug 2012
    Western Australia
    LS1Berlina Was the ultimate polish what removed the white marks from the stone chips? because the last thing I want to do is apply another layer of compounds in the scratches and dents and make it further more difficult for the white marks to be removed especially since there will be a clear layer on top of them. Also do you think it might just eventually come out after multiple washes?
    Also it is good to see another Aussie on here I have been reading this forum for a long time now (lots of good guides) but never had a serious enough question to ask nor knew enough to contribute so never needed to join.
    Aug 2012
    Western Australia
    BINGO53 I was also told by a detailer to do exactly what you are saying but the problem is that the dried wax is in such tiny holes that it would take me forever to complete the job unless there is a detailing brush which is safe to use on all of the car without scratching it? I will try and upload a picture to show you.
    Aug 2012
    Western Australia
    Aug 2012
    Western Australia
  1. does DC 2 Polish remove swirls and scratches
    By brendan1234 in forum Detailing 101
    Last Post: Jun 17th, 2011, 12:54 PM
  2. Replies: 9
    Last Post: May 25th, 2011, 12:55 PM
  3. How to fix RUSTING chips and scratches?
    By mgray in forum Wet-Sanding, Color Sanding, Rock Chip Repair
    Last Post: Jul 28th, 2008, 06:40 AM
  4. Chips and Scratches...Help.
    By usafcrk in forum Tricks of the Trade!
    Last Post: Jun 2nd, 2008, 06:06 AM
  5. Replies: 4
    Last Post: Apr 12th, 2005, 08:57 PM
