Results 1 to 9 of 9
Thread: UQW or QW - What am I missing?
    Jul 2012
    Pdx
    14
    It seems like a lot of work, and it's supposed to be "quick". What am I doing wrong?
    I'm using the standard QW. I've tried misting on a wet car and drying and I've now tried blowing the car with a blower and then misting with QW, then going over it with MF.
    Either method leaves yet more buffing to do.
    It seems I might as well just apply a coat of wax. It wouldn't take that much longer.
    It's supposed to be quick... what am I missing?
    Sep 2005
    Sydney, Australia
    2,091
    35
    Re: UQW or QW - What am I missing?
    The standard QW is not as quick & easy as UQW, but it still should be much quicker than applying a traditional wax.
    Perhaps you're applying too much? One spray per panel/section should be enough...
    Oct 2010
    manila, philippines
    935
    12
    Spray waxes as far as I know is a mist and wipe thing, unless you're using too much which will make most spray waxes hard to use and leave the paint patchy and applying it by allowing it to haze before removal. Which is also another way of applying UQW. Spray on a panel, allow to haze which should happen real quick since its a liquid then remove almost immediately.
    It can also leave the paint uneven if you apply it when the car has become too dirty. In which case I'd UQD first before applying UQW.
    Dec 2011
    Union Bridge Maryland
    39
    I use the UQW but will always go back over with a dry MF rags as a final wipe...
    Oct 2010
    manila, philippines
    935
    12
    Yup, I agree with that... Because eventually the microfiber used in spreading the spray wax will be too saturated, a 2nd microfiber will ensure cleanliness and remove any excess product. If not, the car can look messy, even streaky and smeared.
    May 2004
    840
    18
    I read some folks here do not dry the car when applying UQW. This saves one step.
    32
    18,021
    219
    Yeah, I would guess applied to heavy. It is just a top up, not an actual coat of wax.
    Trabuco Canyon, CA
    15,716
    1074
    UQW will be a much faster and easier application than the original version of Quik Wax. The new version of QW should be much easier to use.
    But it does sound like you might be using too much product, regardless. A simple mist of product onto a panel, then a wipe with your micofiber followed by another quick wipe or two with the dry side of the towel should be all that's needed. As has been mentioned, eventually your microfiber towel will start to become damp with product, at which point you can actually spray a bit less as you work around the vehicle, since that dampness will still transfer product to the paint. Always follow with a quick couple of wipes with the dry side of the towel though.
    Quote Originally Posted by mis3 View Post
    The common method is to spray the product onto a wet panel and then dry, not to skip the drying process altogether. That's a recipe for water spots, and that's never good. You still save a step by doing this, of course.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Jul 2012
    Pdx
    14
    Thanks guys, for all the replies.
    Definitely too much product being applied. I'll cut way down.
    Ive been using the blower method to go once over so the second over is a light dry.
    Ill apply less and see how it goes. Thanks again!
  1. Am I missing anything?
    By Chubbz91 in forum Detailing 101
    Last Post: May 21st, 2010, 10:34 AM
  2. Missing Pic's?
    By Alfaromeodriver in forum Show Off Your Latest Detail Work
    Last Post: Jul 8th, 2008, 04:54 PM
  3. Anything missing?
    By vindaloo in forum Detailing 101
    Last Post: Mar 21st, 2007, 04:10 PM
  4. Am I missing anything?
    By skitelluride531@cubs in forum Detailing 101
    Last Post: Apr 24th, 2006, 02:44 PM
  5. What am I missing??
    By F18lumpy in forum Professional Line
    Last Post: Jan 8th, 2006, 01:34 PM
