Results 1 to 10 of 10
Thread: Test Spot Protocol
    Registered Member h_bomm's Avatar
    Mar 2012
    St. Cloud MN
    169
    3
    Test Spot Protocol
    Just kinda curious as to actually how to do a proper test spot. Say you have moderate swirls on a darker color vehicle and you figure your plan of attack should be Ult Compound, Ult Polish and Ult Liquid Wax. When doing your test spot you obviously tape off your test area and then test out the UC. If you are satisfied with the results of the UC do you then pull off the tape and UC the whole car and tape off a new test area for the UP to see if it's necessary or move onto UP then ULW within the same test area. To me common sense says to UC the car and then do a new test spot but I just want to check in to reassure myself. Thanks!
    Sep 2005
    Sydney, Australia
    2,094
    35
    Re: Test Spot Protocol
    I suppose you could do it either way.
    In your scenario, I personally would prefer to do the UC / UP test spot first. Once I have a clear plan for the vehicle, which I know will work, I then proceed to UC the whole car, then UP the whole car.
    That's interesting - I don't think I've ever done a test spot for wax/sealant..
    Mar 2012
    St. Cloud MN
    169
    3
    I never have either. I usually do a test spot with the UC then if I'm happy with the result then I UC the whole car then I do a test spot with the UP, although the more I think of it a test spot with UP may not be necessary at all, then I UP the car then I just throw wax on with no test spot.
    Dec 2009
    Iowa
    2,288
    29
    Like Davey, I get the testing done and out of the way. Once I get in the "zone" of running the buffer, I just want to keep going.
    In my opinion, doing two small test areas to compare waxes might be difficult. Now two full doors side by side, that would be different. Although for me, I need to see the whole car done to make an evaluation. Do it with one wax and a couple of weeks later do it with another different type of wax/sealant. Again for me, it's an impression I get rather than specific differences.
    David
    32
    18,032
    219
    I think you'll be ok either way, just whichever fits your work flow better.
    And yeah, for the look of polishes/waxes, a bigger area may be needed, or esp if a wax for a longer term test.
    Mar 2012
    St. Cloud MN
    169
    3
    Is there a problem over lapping your test spot with more UC after you have UP on it already?
    32
    18,032
    219
    No, but would remove any oils UP left behind. Or set the finish back if the UC was leaving any marring.
    Mar 2012
    St. Cloud MN
    169
    3
    Probably not a problem though if you still had to go over it with UP anyway I would imagine, huh?
    Sep 2005
    Sydney, Australia
    2,094
    35
    Quote Originally Posted by h_bomm View Post
    Correct..
    Registered Member umi000's Avatar
    Apr 2011
    Manila, Philippines
    105
    4
    I've always worked out the entire combo on the test spot - in your case, use UC, and then UP on the same spot - then applied it step by step on the whole car.
    Francis
  1. test spot has me worried
    By DontRevMe in forum Detailing 101
    Last Post: Apr 27th, 2011, 03:03 AM
  2. How to do a Test Spot
    By Mike Phillips in forum How-To Articles
    Last Post: Jul 2nd, 2010, 01:16 AM
  3. The Reverse Test Spot
    By Mike Phillips in forum Tricks of the Trade!
    Last Post: Dec 15th, 2009, 12:33 PM
  4. Test Spot on Client's car
    By Clutch34 in forum Detailing 101
    Last Post: Nov 18th, 2009, 09:48 AM
  5. [Test Spot] VW NewBeetle
    By Astil in forum The Dual Action Polisher
    Last Post: May 23rd, 2008, 04:25 AM
