Results 1 to 7 of 7
Thread: Pictures from July 28, 2012 - Saturday Open Class
    Trabuco Canyon, CA
    15,709
    1074
    Another jam packed day in Meguiar's Garage! We had a class full of highly enthusiastic detailing fanatics, and quite the challenge with our demo car this time around.
    Not only was the paint on this Toyota Rav4 full of swirls, but the owner's father had gone over spots with a scouring pad and left some really deep scratches.
    This angle really shows the scouring pad scratches - these are much deeper than the typical swirls and as such present much more of a challenge for removal.
    The paint was also just plain dirty, so we cleaned the hood first with Ultimate Wash & Wax Anywhere.
    Claying was definitely needed on this car.
    See what we mean?
    On to our typical test spots - one area by hand, one with the G110v2 buffer. Here we're applying Ultimate Compound by hand.
    Follow with Ultimate Polish and finish with Ultimate Wax.
    On the G110v2 buffer test spot we start again with Ultimate Compound, here on a W8207 foam polishing pad.
    Close inspection shows that the typical swirl marks are gone, but those nasty scouring pad scratches are still there. While diminished in appearance when viewed with natural light, they were still visible and really detraced from the look of the car. Multiple passes with Ultimate Compound couldn't quite do the job - every product has limitations, after all. Had it not been for these scouring pad scratches we could have done it all with UC, but in this case we had to step up to achieve full correction.
    In this case, stepping up meant going with the DA Microfiber Correction System. Here we start by priming the DMC5 cutting disc with D300 Correction Compound.
    With the disc on the paint we finish the priming step, then blow the disc out with compressed air.
    Once blown out, the disc is fully primed and ready to start with the heavy correction needed to remove those scouring pad scratches.
    3 pea sized drops of D300 is all that's needed for our first section.
    Speed setting 4 (4800 opm) on the G110v2, heavy pressure, and slow passes.
    Now that's more like it!
    Out in the sun you can see the results of the hand application test spot (left side) and machine applied test spot (right side). Even the hand applied section is a huge improvement of the untouched area. It looks blacker and richer, and judging by all the swirls still evident in the tape line strip down the center, we did a really good job removing the typical defects by hand. The deeper marks you see in the hand applied spot are mostly the scouring pad scratches. But the machine applied side looks almost brand spanking new!
    Closer up you can see the results even more clearly. That's the hand applied section in the bottom of the picture, machine applied at the top. In the middle, where the tape line was, you can clearly see not just the swirls but the scouring pad scratches, too.
    So now that we have a process lined up, it's time to put the G110v2 into the hands of our students and let them get a feel for it. As always, we offer hands on (literally) training to ensure that their technique is spot on. Of course we had to let the car owner go first!
    Hands on - keep the pressure constant, keep the pad flat, keep the buffer moving.
    Teamwork!
    Thanks to everyone for coming out and spending a big chunk of a beautiful Saturday with us, and to Ann for letting us use her car for our demo, and to Greg for being our photographer during the demo.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Jun 2012
    Los Alamitos, Ca.
    Hi Michael.
    I really enjoyed the class you held on the 28th, of July. You have a great way of keeping us interested in the information provided. Some classes, we old guys have a hard time staying a wake, but not in your class. A job well done. I was at Wyo-Tech the next day for a car show and that was the talk of the day from Bob Lee and myself. Thanks again for a great class.
    Rick Crawford.
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,154
    52
    Re: Pictures from July 28, 2012 - Saturday Open Class
    Awesome job, Mike! I didn't think you would get out the scouring marks without breaking out the Dewalt, a polishing wool pad and some M105. Nice to see the effectiveness of the DAMF system in play!
    Jun 2012
    Edwards CA
    Mike,
    No problem with taking the pic's, glad some of them turned out . I had a good time in the class, learned a lot about buffer technique to help with improving my skills.
    Registered Member s word's Avatar
    Jul 2012
    west covina
    258
    3
    Mike, I learned a lot in the class. Also found that some of the things that I thought I knew, were misconceptions. Also, the basic tip of running a normal pressure hose over the car to sheet of the water cut my drying time by almost 80%. I had asked if I could use the DA on the piano black finish on my CC. I finally had a chance to do so last night. Much harder to remove the spider web than I thought but I can say the the spider web effect and bird drop etching is 100% removed, the pieces look brand new. Thanks for the tips.
    Aug 2010
    Fairmont, MN
    69
    878
    Quote Originally Posted by ClearlyCoated View Post
    NOW, I'm REALLY impressed with the DAMF! I would have never thought of short of rotary and 'wool' would have removed those scratches.
    Bill
    I <3 my IS F CreamPuff's Avatar
    Feb 2008
    Socal, CA
    28
    241
    Uh....why was a scouring pad used on the car? Are they trying to remove the paint? LOL
  1. Pictures from July 14, 2012 - Saturday Open Class
    By Michael Stoops in forum Pictures from Saturday Classes
    Last Post: Jul 16th, 2012, 01:19 PM
  2. Pictures from July 23rd, 2011 - Saturday Open Class
    Last Post: Aug 1st, 2011, 08:53 AM
  3. Pictures from July 25th, 2009 - Saturday Open Class
    By Mike Pennington in forum Pictures from Saturday Classes
    Last Post: Sep 16th, 2009, 03:24 AM
