Results 1 to 10 of 11
Thread: Help- Ultimate Wax Won't Come Off
    Jul 2012
    Pdx
    14
    Hi All-
    Great forum here.
    So last night I washed, clayed, cleaner waxed (because I had it laying around), and Ultimate liquid waxed our Acura MDX, black in color.
    All in all it went well until the Ultimate wax. I way over applied not realizing it won't crust up like a traditional carnuba. Now I've got what look like smears, it's really wax oils, all over the damn place. I think they're gone and then the light shifts and there they are again.
    Am I safe to assume that a car wash or two will remedy this problem?
    Formerly 101impala Moderator Andy M.'s Avatar
    May 2004
    Philadelphia, PA
    45
    3,956
    341
    Re: Help- Ultimate Wax Won't Come Off
    Try a small test spot and some more wax. Applied lightly. Like removes like. If not maybe claying will help.
    Andy
    Andy M. Moderator
    Jul 2012
    Pdx
    14
    Geeze I'd hate to reclay the entire again.
    Thanks for your reply. I like the removal process of the good old carnuba type wax much better.
    May 2004
    Philadelphia, PA
    45
    3,956
    341
    Oh and Welcome to MOL!!!
    Andy M. Moderator
    32
    18,024
    219
    Certainly nothing wrong with waiting and washing, there isnt going to be any damage or anything.
    You can also try using a wet towel, then a dry towel to remove.
    Registered Member Buck91's Avatar
    Apr 2011
    Southeast Michigan
    128
    4
    I had this issue with ULW after hitting my '96 GT with UP. That was last year and I don't really remember what came of that but I think I did pretty well just using either Ult. spray wax or UQD and buffing by hand with a soft MF.
    Jul 2012
    Pdx
    14
    I washed dried it, let it sit overnight and first thing gave it another go. Here's some tips that might help others:
    Searching and reading kept leading my back to the same thing, use less. Less is better. Then, this video: http://www.meguiarsonline.com/forums...-with-a-G110v2
    I used less than an ounce.
    Micro fiber towels. The extra soft ones did not work as well even on the 3rd final wipe. The standard MF are better
    On 1st initial wipe make two passes using very small circular motions. Super small circular being key. Larger circular motions didn't remove the wax nearly as well. After the 2 pass initial wipe immediately do a 3 rd pass with a fresh MF towel.
    Fresh towels help a lot
    As someone else stated. Don't wax the entire car and the wipe. Wax, wait 3-5 minutes and wipe. I started with the hood, set the timer on my watch and at 5 minutes wiped the hood. By that time I had one entire side of our MDX coated in wax. I wiped the hood as described above which took 5-6 minutes. I then started the wiping the side. So I had the hood and one side done before I had wax applied to the back and other side.
    The entire process including final wipe took 58 minutes. Wax was applied with a wax spreader and terry cloth bonnet.
    Much better results this time around. The car simply looks awesome and we're seeing the blue flake we haven't seen in a long time. A definite different kind of shine, but we're happy with it. That combined with the fact you can apply in sun, it won't stain trim, and if applied right the bottle will last a longtime and we'll keep using it.
    In between the plan waxes/paint care days we plan to wash with Gold Class and dry with the Quick Wax product that can be applied while wet or dry. Any problems with that plan??
    Thanks for the info. Hopefully I can help someone out with my two experiences in this post. If someone can add to my positives based on their own experience than great!!
    Last edited by Mark Kleis; Aug 3rd, 2012 at 01:01 AM. Reason: Family friendly language
    32
    18,024
    219
    Sounds good.
    Registered Member goldenlight's Avatar
    Jun 2011
    North Carolina
    176
    3
    quick detailer should do the trick.. with quality microfiber towels..
    Mar 2012
    Central, AR
    133
    3
    The first application of ULW on my 2011 F150 left a haze the following morning. I hit it with a quality MF and Meg's Quick Detailer (red bottle) and it really popped. I now use ULW exclusively on my 1994 Ford F150 Lightning with Oxford White Clearcoat paint. I find that hand application of ULW work's best.
  1. Ultimate Polish + Ultimate Black + NXT 2.0 = Happy Mini
    By cydewaze in forum Show Off Your Latest Detail Work
    Last Post: May 25th, 2012, 06:12 PM
  2. Replies: 4
    Last Post: Mar 28th, 2012, 11:05 AM
  3. Ultimate Black Plastic Restorer vs. Ultimate Protectant
    By billoftt in forum Consumer Line
    Last Post: Jan 31st, 2012, 05:32 PM
  4. Replies: 2
    Last Post: Sep 3rd, 2011, 07:16 PM
  5. Replies: 4
    Last Post: Aug 26th, 2011, 05:37 AM
