Results 1 to 10 of 11
Thread: What can be used before Show Car Glaze?
    Aug 2011
    Livonia, Michigan
    Last fall I completely rejuvenated the paint on my 89' Ford Van (Single Stage paint). M105, Ultimate Compound, and M205 were all used to remove heavy oxidation and prep the paint for finishing products. I then applied three coats of M7, two coats of M21, followed by two coats of M26. Definite overkill but I enjoyed it. The vehicle sits in the garage and all I have done since is a couple spray downs with D156. I would like to hit her with several coats of M7 again. I am wondering if I first hit her with a thorough cleaning/sealant of M20 if the M7 could still get to the paint to nourish it. I really like M20 and would prefer not having to go back to the M205. I guess my question is if the M7 can nourish the paint with the M20 already applied?
    Thanks
    David
    32
    18,014
    219
    Re: What can be used before Show Car Glaze?
    Did you have issues with the #205?
    You really would want just a cleaner, or cleaner/polish before the #7. Maybe look at #80.
    Aug 2011
    Livonia, Michigan
    No, I had no issues with #205. I just wanted to go with the least aggressive product I could. The #205 does have the oils in it so I think I will just go ahead with that again. I will look into #80 as I do like trying new products. Thanks Matt.
    Jun 2010
    413
    8
    I use a lot of M07 on SS paint. My process is to do a clay job first, which I feel removes enough of the multiple waxes and/or sealants that the oil content of the M07 gets into the paint, I apply M07 using a folded MF cloth with a fair amount of pressure. All you need to do is look at your cloth for your paint color to know you're getting through any wax or sealant to the base paint material.
    Bill
    Aug 2011
    Livonia, Michigan
    Bill
    That is a good point. Using the clay bar is quite easy and that should be done anyways. Of all the cleaner/polishes that Meguiars produces, M09, M80, M82 etc., which product contains the most nourishing oils? Thanks.
    David
    32
    18,014
    219
    #80.
    Aug 2011
    Livonia, Michigan
    #80.
    Thanks.
    May 2011
    Australia
    93
    What about UP? Does some cleaning and has a lot of polishing oils.
    Registered Member umi000's Avatar
    Apr 2011
    Manila, Philippines
    105
    4
    Quote Originally Posted by LS1BERLINA View Post
    Was thinking the same thing.
    Francis
    Jun 2010
    413
    8
    Quote Originally Posted by davidcam View Post
    David
    I've used a lot of M07, M80, M09 and M03, but no M82, so here's my opinion: M09 was designed for the "hi-tech" finishes as a swirl remover, so it's not as high in oil content as the products targeted for SS paint such as M03 and M80. M80 and M03 are somewhat close in oil content IMO, but M80 has more cutting ability than M03, so I get better and faster results on SS paint. Both are pad-dependent on the level of cut, but considering the wider range of M80, nowadays I use it far more than M03.
    Bill
  1. Differences between New Car Glaze and Show Car Glaze?
    By ChrisGottschalk in forum Professional Line
    Last Post: Jun 7th, 2012, 01:29 PM
  2. M7 Show Car Glaze
    By Tom_DS in forum Professional Line
    Last Post: Nov 18th, 2010, 12:28 AM
  3. Show Car Glaze v. New Car Glaze
    By RGP in forum Detailing 101
    Last Post: Sep 12th, 2009, 05:44 AM
  4. #7 Show Car Glaze
    By RockCrushin150 in forum Detailing 101
    Last Post: Oct 12th, 2005, 06:22 AM
  5. Show Car Glaze
    By yogibear458 in forum Detailing 101
    Last Post: Apr 6th, 2005, 10:19 AM
