Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Can't remove the haze / blotchiness after applying Gold Class
    Registered Member Nezil's Avatar
    Jul 2012
    Sunnyvale, CA
    54
    Unhappy Can't remove the haze / blotchiness after applying Gold Class
    I have been going over my car panel by panel using the following process:
    Ultimate Compound with Polishing Pad -> Ultimate Polish with Finishing Pad -> Gold Class Carnauba Plus Liquid with Finishing Pad
    Initially I was quite impressed, particularly with UCs cutting ability and resultant shine, but I'm now getting very frustrated.
    I'm working late evening, so I don't have any sun to check my work, and am instead relying on a Brinkmann Dual Xenon. Once I've finished a section and pack up for the evening I'm quite impressed, but by the time morning comes the car is covered in a slightly blotchy appearance that is almost impossible to get rid of.
    At first I thought this might be due to the Gold Class sweating overnight, but I think this would wipe off quite easily, especially with a mist of GCQD. The thing is, it doesn't... If anything the QD makes things worse! Where the QD has been directly sprayed seems to leave the paintwork darker, and wiping it around the paint does not seem to give even coverage. Even spraying on excessive amounts of QD doesn't seem to work as the different areas dry at different rates.
    I should point out that all of this observation is happening in the morning under mostly fluorescent lighting. Once I move the car out into the sun, the blotchiness is almost impossible to see, but instead appears as a kind of patchy greasiness.
    Thinkinkg about this in more detail now, I first noticed this effect when I applied Zaino sealant after the UP stage. I guessed at that point that it was because Zaino wanted a fresh clean panel to start with, and perhaps there was some incompatibility with UP. Now I am beginning to think that UP is to blame again, and the polishing oils left behind are preventing GCCP from bonding to the paint.
    Could this be possible? Should I really need to IPA wipe down each panel before applying GCCP wax?
    I like the (initial) look of GCCP, but this issue is making me seriously consider going back to a Zaino routine, which would be a shame because I fancied a change.
    Neil.
    2012 Jaguar XF Portfolio Sport / Midnight Black Pearl Exterior / Ivory & Charcoal Interior
    2007 Honda Element SC / Nighthawk Black Pearl Exterior / Copper & Black Interior
    32
    18,024
    219
    Re: Can't remove the haze / blotchiness after applying Gold Class
    How heavy is the Gold Class wax being applied? How long to dry?
    Jul 2012
    Sunnyvale, CA
    54
    I'm applying with a DA, so that should be fairly light application.
    I'm leaving it at least 30 ~ 45 mins to dry.
    Dec 2009
    Iowa
    2,287
    29
    Just some clarification questions. Are you working the Ultimate Compound and then wiping it off before it dries? Are you working the Ultimate Polish and then wiping it off before it dries? Are you doing a swipe test before buffing off the Gold Class wax?
    What sort of temperatures are you working in?
    Thanks,
    David
    Jul 2012
    Sunnyvale, CA
    54
    Yes I am wiping both UC and UP off before they dry, working in roughly 2x2 ft sections, I wipe off each section before moving to the next.
    Swipe test... I'm not sure what you mean by this... Could be my problem?
    Temperatures in my garage are between 20 and 25 centigrade (68 ~ 77 Fahrenheit)
    32
    18,024
    219
    This seems to have a few pics of "thin" wax application, just to be sure.
    http://www.meguiarsonline.com/forums...ax+application
    The swipe test is just a matter of taking a finger or finger wrapped in a towel, and swiping the wax you applied, to see if it wipes off clean/clear. If there is any smearing, the wax should dry longer.
    Jul 2012
    Sunnyvale, CA
    54
    Yep, that looks like how I did it. I think the only difference being that I am not doing the whole car at once, so I never quite get to the point of not needing to add more product, just a panel or two at a time; I only have time to do the whole process to part of the car each night, but I'm nearly finished now. I would say that to do the roof and down the A, B and C pillars I did a very thin swirl of GCCP on the pad about 3, maybe 4 times maximum.
    I think it is possible that I didn't leave the wax long enough to dry. I thought that 15 minutes was enough, and that 45 would be overkill. Most times I applied the wax, cleared up, watched a TV show, then went back and removed the residue.
    Even assuming that removing too soon is my problem, and I'm not convinced it is:
    What could I do to rectify it?
    Why doesn't GCQD remove these blotches in the morning?
    How can we explain that this same effect appeared when I used Zaino as an LSP as well?
    32
    18,024
    219
    It is possible waxing by hand may be easier for only one panel... They way the machine pads absorb a lot at first can make things trickier at first. I know if I get smearing, it is more likely to be where I started.
    Not sure about all the answers, but it seems like ignoring it or waiting for rain/the next wash often solves the issue. Might just be that a little longer in the sun finishes the wax drying.
    If the wax is the issue (or things under it), in theory you would have to remove the wax, and the QD sprays are made to try to not do that.
    Have not used Zaino products.
    Trabuco Canyon, CA
    15,721
    1074
    It sounds as though you're applying a properly thin coat of Gold Class, that's for sure. It does sound like you may not be letting it dry long enough, and drying time can and will be extended depending on temperature and humidity. This is true not only of Gold Class, but pretty much every other wax/sealant on the market. Of course, some will dry faster than others in any condition, but all will be impacted to some degree by temp and humidity. This would certainly explain why your previous method of applying, cleaning up, and watching a TV show resulted in an easy wipe off with no streaking or blotchy appearance. A properly thin coat of wax/sealant should still wipe off very easily even if you let it sit on the paint for a couple of hours.
    It could be that your application of Ultimate Polish wasn't wiped off quite as thoroughly as it could be, but the presence of UP in and of itself won't cause any bonding issues with Gold Class. It might with the Zaino because they are pretty emphatic about the surface being totally devoid of anything before applying their sealant (but in all honesty, I personally have my doubts that this is a critical as they make it out to be). But unless you're struggling to remove the UP, we really don't think this is the issue here.
    Since you're doing this work in the evening it's very likely that the humidity is rising and playing a big role in drying time. Sunnyvale is close enough to the ocean for this to be a real issue: here in Irvine when we hold our Open Garage sessions on Thursday nights we've seen situations where people apply a wax to a black car just after dark, let it dry for 15 to 20 minutes and then see this exact same streaking/blotchy issue. The short dry time and higher level of humidity in the air conspire to create this problem. Even Zaino talks about drying time being impacted by humidity and temperature, and that their product needs to be completely dry before removal. The use of a QD the following morning won't rectify the issue because by then the uneven application of the LSP has set in and you can no longer "move the product" around to even it out. You should, however, be able to correct this with a light application of a cleaner wax that dries pretty quickly, like ColorX or even good old A12 Cleaner Wax. But definitely give even this type of product plenty of time to dry fully before wipe off. You can then apply Gold Class over it a day or two later, after correcting a few other panels, or however you wish to approach it. It may even clean up by simply applying a fresh coat of Gold Class and letting it dry fully before removal, making the cleaner wax unnecessary.
    One point about letting a wax sit on the paint for an extended period of time: in very high humidity conditions, and we're talking Houston, TX or Miami, FL humidity here, you run the risk of the hazed wax actually picking up moisture from the air after a couple of hours or more. This can not only lead to potential streaking, but it can also make removal more difficult than it needs to be. In very low humidity situations where any wax/sealant will dry in just a few minutes (think Phoenix in August or SoCal when the Santa Ana conditions drop humidity to single digits) you can leave a properly thin coat of wax on the car for 6 hours or more and it will still wipe off with ease. You won't really gain anything from doing it, however, and we really don't recommend the practice, but it can be done. Just not in Houston when humidity is so high the air actually feels thick.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Jul 2012
    Sunnyvale, CA
    54
    Murr1525,
    Thanks for your suggestion. I wonder too if a wash might solve some of these problems, but I don't really want to do that yet since I've not finished compounding the rest of the car.
    Michael,
    Thanks also for your suggestion, though I think you may have misunderstood what I was saying. I have never (yet) had GCCP leave a good finish the next morning; every day it has been blotchy, even after the times that I've watched a TV show for 45 minutes. The blotchy / streaky effect does not seem to be present when I take the wax off at night, it's the next morning that I really notice it.
    You are right that the humidity does rise in the evening here, though not quite as badly as it does further up the peninsula! That could be having some influence on things, and I will try leaving the wax on for a little longer.
    I work from home most of the time, and am now in fact. I might try to get a coat of GCCP on this afternoon before it gets dark and see if the streaking / blotches are there still.
    The effect is far more noticeable on horizontal panels like the hood and trunk, so I think I'll do a little test... one half of the hood and trunk I will wipe clean with IPA, hopefully starting from nothing, and the other side I'll do nothing in preparation, and give both panels new coats of GCCP, again with the DA. Both of these I'll leave to dry for more than an hour, and hopefully we'll see in the morning how things have turned out.
    My personal feeling now, is that the issue is caused by one of the following:
    • Ultimate Polish leaving behind some oils that are creating the smearing
    • Me not leaving the GCCP long enough time to cure
    • GCCP requiring a wash / rinse after removing the wax
    I really hope I can get a good finish with GCCP... I want so much to like this product!
  1. Replies: 2
    Last Post: Apr 2nd, 2012, 07:07 PM
  2. Applying NXT on top of Gold Class
    By angeloaa in forum Detailing 101
    Last Post: Oct 19th, 2010, 01:29 AM
  3. Should i polish using #7 before applying Gold Class Wax
    By 79elcamino in forum Detailing 101
    Last Post: Sep 4th, 2009, 07:15 AM
  4. will clay bar remove haze?
    By stangAtang in forum Detailing 101
    Last Post: Jun 21st, 2008, 11:34 AM
  5. applying gold class trim detail
    By JDMb18c in forum Consumer Line
    Last Post: Feb 11th, 2008, 11:02 AM
