Results 1 to 5 of 5
Thread: Bird dropping etching
  1. #1
    Registered Member
    Join Date
    Nov 2011
    Location
    Southwest Minnesota
    Posts
    141
    Rep Power
    3
    Wondering what process to use to get it out. Also scraped at it with fingernail and seems like the clear is coming off?
  2. #2
    Registered Member zbestwun2001's Avatar
    Join Date
    Aug 2011
    Location
    Encino, Ca.
    Posts
    151
    Rep Power
    3
    Re: Bird poop etching
    How long has it been on the paint?
    I wouldn't suggest continuing to scrape it.. If you have some UQD, spray some on a clean MF Towels and place the towel over the spot and let it sit and soak into the poop.
    It should soften it up to the point that you can "gently" pinch the rag between 2 fingers and pinch it into the rag.
    If it's like pigeon or crow or a healthy LARGE bird that obviously just had a large meal.... let it sit an extra while.
    Hopefully it hasn't been on there too long. My body guy says these things come back to haunt you later on down the line if let sit too long, even if it looks like it's all off when you work on it.
  3. #3
    Registered Member Marc08EX's Avatar
    Join Date
    Aug 2004
    Location
    Glendale, AZ
    Age
    29
    Posts
    2,730
    Rep Power
    41
    Re: Bird dropping etching
    What color is your paint? How long was the bird poop left there? Do you mean that the paint is chipping off with your fingernail? That's not good.
    To remove bird drop etchings, you need a good paint cleaner such as Ultimate Compound. Apply it with a foam applicator pad and concentrate on the affected area.
  4. #4
    Registered Member GoZoner's Avatar
    Join Date
    Aug 2010
    Location
    Santa Barbara, CA
    Posts
    58
    Rep Power
    3
    When removing, don't wipe it. Birds have sand in their droppings (apparently aiding their digestion or just a by-product of finding food) which won't be kind to your paint.
    2011 Honda CR-Z; 2006 Acura TSX; 2000 Acura Integra
  5. #5
    Registered Member
    Join Date
    Nov 2011
    Location
    Southwest Minnesota
    Posts
    141
    Rep Power
    3
    Its dark mocha metallic. Was out of town so it could have sat a maximum of 2 days. Some off the clear seem like it came of in a spot. I think i am going to use sum touch up clear over it. I will definitly uc to see if it helps.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Bird dropping --> patch on the car
    By richkan in forum Detailing 101
    Last Post: Jun 21st, 2011, 07:11 AM
  2. Bird dropping Stain?
    By ChpStcksRlz in forum Detailing 101
    Last Post: Apr 5th, 2010, 03:07 PM
  3. Bird Dropping Stains
    By Beege1952 in forum Detailing 101
    Last Post: Feb 18th, 2010, 02:34 AM
  4. Replies: 22
    Last Post: Dec 25th, 2009, 01:07 PM
  5. How to remove the etching left by a bird dropping with ScratchX
    By Mike Phillips in forum Detailing 101
    Last Post: Sep 16th, 2004, 08:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
