Results 1 to 3 of 3
Thread: Want to buy the right product
    Jul 2012
    Potosi, Mo 63664
    I just painted my car. It's a base coat / clear coat job. I have a little dust and some orange peel in the clear coat. What products / process is recommended. I'v heard I need to knock down the orange peel with hard block sanding with a 1000 then 1500 wet sanding and after DA'ing with Meguiars M150 then 250 then glaze. Is that correct?
    Registered Member MarkFilgerleski's Avatar
    Oct 2011
    Hanscom Air Force Base, Massachusetts
    126
    3
    When did you have it reprinted?
    Mark
    Trabuco Canyon, CA
    15,666
    1073
    Re: Want to buy the right product
    If you have enough clear coat applied so that you can block sand with 1000 grit, then it's OK to do so. Just make sure of that first! If you finish sand at 1500 grit, especially by hand, you're going to be seriously challenged to remove those sanding marks with a DA buffer, even if you use M105. And to pull them out with a rotary is going to require a fairly high level of rotary skill in the first place. Even then, do yourself a favor and finish down with 3000 grit - it's much less invasive to the paint than grinding away with a wool pad trying to remove 1500 grit marks, and overall it will make the job go faster and easier, too.
    Have you ever attempted to wet sand before? Any experience with a rotary?
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
  1. What Product?
    By Octax in forum Interior Care
    Last Post: May 16th, 2006, 08:07 AM
  2. what product(s) to use?
    By LAfirefytr in forum Detailing 101
    Last Post: Feb 4th, 2006, 09:10 PM
  3. Never Seen this Product Before??????
    By Snowman in forum The Break Room
    Last Post: Jan 16th, 2006, 12:51 AM
  4. Product Help!!!
    By bigman66 in forum Detailing 101
    Last Post: Jun 26th, 2005, 11:50 PM
  5. this is not a Meg's product but WOW
    By onawrxhigh in forum Detailing 101
    Last Post: Jun 11th, 2005, 12:44 PM
