Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: M105 Ultra Cut vs. Wet Sanding - Need Advice
  1. #1
    Registered Member
    Join Date
    Jul 2012
    Location
    NJ
    Posts
    21
    Rep Power
    1
    Well unfortunately I have a lot of scratches on my car's roof, hood, and rear deck lid. From a few feet away you can't see them, but up close it looks like the car was wiped with an abrasive brush. I think what caused it was hasty snow/ice removal in the winter. There doesn't appear to be any kind of clearcoat failure (as posted in the thread on that topic). These are definitely scratches.
    Anyway, my first attempt to get rid of the scratches was with the Deep Crystal paint cleaner. That didn't work so I tried Scratch X 2.0 and applied to a test spot. After a few applications with "passion" there was little improvement if any. I thought for sure the Ultimate Compound would do the trick but no luck with that either. Again I did 3 applications and the test area still looks the same as the other affected areas. All my applications were done by hand using a foam applicator pad.
    So I'm thinking my next step is to try the M105 Ultra Cut compound or wet sand (followed by compound), then polish and wax. I'm certainly no detailing expert but I have conquered a couple paint catastrophies with my car so I've learned a thing or two, but this seems like a really challenging task. It would be my guess that these scratches are fairly deep in the clearcoat and that the clearcoat itself is fairly hard.
    I'm thinking I have no other options but to break out the big guns and do the wet sanding or the ultra cut. I don't have a rotary or orbital buffer so I will either give in and buy one or do the work by hand. Hopefully I can figure out how to post pics here...
    Any thoughts on what I should do and why? Thanks in advance!!!
  2. #2
    Registered Member
    Join Date
    Jul 2012
    Location
    NJ
    Posts
    21
    Rep Power
    1
    Re: M105 Ultra Cut vs. Wet Sanding - Need Advice
    Scratch marks on roof:
    Scratch marks on roof (different angle):
    Car from 3 feet away:
  3. #3
    Registered Member Marc08EX's Avatar
    Join Date
    Aug 2004
    Location
    Glendale, AZ
    Age
    29
    Posts
    2,749
    Rep Power
    41
    I did a car that looked like that and was able to revive it temporarily. Within a year, his CC eventually failed. To me, that looks like a different type of CC failure. At least on the verge of starting it. I really hope I'm wrong though.
    Here's the link to the detail I did years ago:
    What do you guys think about this one (Results are in!)
    Take a look at the trunk's condition prior to detailing. It looks similar to your pic. They look more like scratches.
  4. #4
    Serious Clean Showmob's Avatar
    Join Date
    Jan 2012
    Location
    Bend Oregon
    Posts
    138
    Rep Power
    3
    Before you think about sanding give a da polisher a try removing scratches by hand is tedious and way more trouble then its worth. A polisher will give you a deeper cut and better results with less effort. I would try ultimate compound and 105 with a da before wet sanding.
    Even the best cars look like junk when they are not clean
  5. #5
    Registered Member
    Join Date
    Jul 2012
    Location
    NJ
    Posts
    21
    Rep Power
    1
    Quote Originally Posted by Showmob View Post
    That is kinda what I was thinking too. It's the next logical step. Wet sanding is last resort.
  6. #6
    Registered Member
    Join Date
    Jul 2012
    Location
    NJ
    Posts
    21
    Rep Power
    1
    Quote Originally Posted by Marc08EX View Post
    I don't think the CC is failing, it definitely looks like a bunch of scratches but the CC is not peeling or flaking or anything.
    Thanks for the responses guys!
  7. #7
    Registered Member
    Join Date
    Jan 2005
    Posts
    17
    Rep Power
    9
    Definitely get a "real" polisher (rotary or DA) and try 105 before you wetsand. Wetsanding is going to leave marring behind that will probably need 105 to clear up anways...your arm will fall off if you have to remove wetsand marring by hand.
    MCA - Nothing special...just my initials
  8. #8
    A proud Meguiar's Detailer! Please Wash Me Detailing's Avatar
    Join Date
    Jul 2011
    Location
    Rancho Santa Margarita ca 92688
    Age
    45
    Posts
    1,201
    Rep Power
    14
    105 works wonders.
    Your paint looks like cc failiur but its a pic.
    105 is always my go to.
    By hand is rediculious, you need mechanical power to do tge job right.
  9. #9
    Registered Member
    Join Date
    Jul 2012
    Location
    NJ
    Posts
    21
    Rep Power
    1
    Yeah I'm definitely going to buy a DA polisher then in the next week or two. I will try using the Ultimate Compund first and if no luck then it will be the 105. If the 105 leaves any scratches behind (as far as I know it really shouldnt) I guess I can smooth it over with Scratch X 2.0 or the deep crystal paint cleaner.
    Are there any particular pads you guys recommend I use for the DA with the 105? And is there any benefit to using the DA over rotary, or vice versa?
    I don't think it is CC failure. This didn't happen on it's own. Last winter we got a couple terrible snowstorms and I remember hastily removing snow & ice with a scraper and after that I started noticing the scratches. They are on all panels of the car where snow accumulates. There is no paint fade, haze, or chipping/peeling. I will post more pics that are not taken in direct sunlight. My guess is that the clearcoat is very hard and that's why the Ultimate Compound by hand didn't help. So hopefully the DA will work. Thanks again.
  10. #10
    Registered Member andytsang's Avatar
    Join Date
    Feb 2012
    Location
    San Jose, CA
    Age
    49
    Posts
    132
    Rep Power
    3
    If you have to go wet sanding, please take a look of this thread by Mr. Stoops
    The Power of 3000 Grit
    Hope this help.
    Last edited by andytsang; Jul 11th, 2012 at 03:28 PM. Reason: forgot to mention the author
    2010 Subaru Legacy GT - Graphite Gray Metallic
Thread Information
Users Browsing this Thread
Similar Threads
  1. M105 Ultra Cut Compound - New Formula DA Polisher Approved
    By Mike Phillips in forum Professional Line
    Last Post: May 4th, 2010, 04:24 PM
  2. M105 Ultra Cut Compound - New!
    Last Post: Sep 6th, 2009, 12:47 AM
  3. Meguiar's M105 Ultra Cut ?
    By JG_Detailing in forum Detailing 101
    Last Post: Jul 23rd, 2009, 11:49 AM
  4. Quick M105 Ultra Cut Compound Questions
    By Chex in forum Detailing 101
    Last Post: Jun 28th, 2008, 08:06 AM
  5. M105 Ultra-Cut Compound Kit - New
    Last Post: Mar 27th, 2008, 12:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
