Results 1 to 10 of 14
Thread: Clear coat turns white when wet, clear after drying
    Mar 2011
    Los Angeles, CA
    8
    3
    Hi guys,
    I recently picked up a 95 range rover with only 15K miles. It looks new but apparently somewhere along the line it was resprayed or recleared according to the previous owner, details were spotty. Anyway, when I washed the car last week a bunch of milky white spots appeared, they look like old water spots but when the car dried they disappeared. I went over the whole car with Ultimate Compound using a Porter Cable and then applied Synthetic Sealant. Today I washed the car again and the spots were back and then disappeared just like before. When the spots first appeared I rubbed at one pretty good and when it dried there were scratches making me think the clear is pretty soft. I'm wondering if the clear is failing, if so how long it will last? If I need to respray the clear does the entire clear layer have to be sanded off first, it even spots in the door jams. Anyone else experience this with a range rover, it's even spotting in places that I think they would have masked for a respray so I'm wondering if this is normal for even factory paint?
    Thanks!
    Registered Member NZ ECO1's Avatar
    Apr 2012
    Christchurch, New Zealand
    26
    Re: Clear coat turns white when wet, clear after drying
    Hi,
    Hard to say without pics. Could be the beginnings of clear failure but the door jams probably wouldn't be affected if that was the case. What I can say is that Range Rovers can be a bit ropey on the quality side at the best of times and paint from that era (95) will be starting to show its age now unless looked after fastidiously - even with low mielage, which may explain the respray. Get some pics up if you can and someone will be able to tell you what you are dealing with
    Registered Member rst08tierney's Avatar
    Dec 2009
    Thousand Oaks, CA
    244
    6
    Hmm.....is the vehicle a salvaged title by chance?
    Mar 2011
    Los Angeles, CA
    8
    3
    Clear title with maintenance/recall history. It was just used rarely.
    Mar 2011
    Los Angeles, CA
    8
    3
    will try to recreate the issue and snap some pics tomorrow.
    Apr 2012
    United States
    60
    It sounds like you got a great deal. Even if the paint is questionable, 15K and barely used. Take care of it and if you have to repaint it ...big deal.
    Mar 2011
    Los Angeles, CA
    8
    3
    Definitely happy with the purchase and would be willing to respray if necessary, just trying to figure out what I'm looking at, and if it does need a respray if I need to sand this celar layer completely off first to correct the issue. Really strange, looks perfect after drying and sitting for a bit. I washed and took some photos yesterday.
    http://s1067.photobucket.com/albums/...t%3Dpaint2.jpg
    http://s1067.photobucket.com/albums/...t%3Dpaint1.jpg
    Aug 2006
    Orange County, CA
    248
    9
    Quote Originally Posted by invstor17 View Post
    Definitely could be clear coat failure but I'm used to seeing the clear coat staying white and not recovering after drying.
    From what you've described, it sounds like the clear coat has poor water resistance. I've seen clear coat paints (used on furniture) have similar problems - when wet it becomes foggy but becomes clear after it dries for a period of time.
    A wild guess - maybe the repaint was done with incorrectly mixed clear coat or poor quality clear coat.
    Any additional info on the repaint?
    Andy W.
    Bimmers - '72 Tii, '74 Tii, '88 M3, '89 E30 - S52, & '01 330i
    Ford - '91 Ranger
    Mar 2011
    Los Angeles, CA
    8
    3
    Unfortunately no addl. info on the repaint. It was owned by a celeb and getting any details from the go betweens was like pulling teeth
    If anyone else has experienced this on their own car I'd be interested to hear if it stayed the same over time or if the clear began to fail while dry eventually.
    Thanks!
    Aug 2010
    Fairmont, MN
    69
    877
    I don't have any ideas, but I do have a question...Are the 'white spots' always in the same location or do they move around?
    Bill
  1. Clear coat over powder coat, best way to polish?
    By wolphe in forum Detailing 101
    Last Post: Jun 28th, 2011, 04:52 AM
  2. Replies: 18
    Last Post: Mar 24th, 2009, 12:55 PM
  3. Clear coat with a flattening agent "matte clear"
    By evilpu in forum Detailing 101
    Last Post: Feb 19th, 2008, 06:37 PM
  4. 91 acura base coat clear coat?
    By mini44 in forum Detailing 101
    Last Post: Oct 4th, 2006, 06:18 PM
  5. Clear Coat Problem / Turned Milky White in Spots
    By 192 Viper in forum Consumer Line
    Last Post: Jul 17th, 2005, 06:13 PM
