I've had my DA polisher (G100) for probably over 5 years now, though I probably don't have as much experience as most people on here, as I only polish my own cars and family's / friend's cars.
Several people have suggested that Mazdas typically have very soft paint, and given how easily my car's paint seems to scratch I figured they were probably right.
So once a year I do a full clay / polish / wax on my car (2008 Mazda Miata) and my wife's car (2007 Mazda 3). Our cars are parked outside under trees all the time, so even though I use grit guards and all of that, I still seem to end up with a small amount of fine scratches I have to polish out.
Every year I start out with the thought of soft clear coat and try to go at them with M205 on a finishing pad at speed 4 / light pressure. And every year it seems not to work. So I step it up to M205 on a polishing pad, then speed 5, smaller area, more pressure, even using a water spray to lengthen the time I can work the M205. And every time I look at the results, it seems to not make a dent at all. I've even tried multiple passes on the same area. So eventually, I work my way up to M83 and then finally give up and go to M105. The M105 always seems to do the trick and I've found that if I spray with water and work it a little longer with lighter pressure towards the end, I don't even end up with much micro-marring to take care of.
So what gives? Do we happen to have a range of model years where Mazda switched to harder paint? Or does it sound like from my description that I may be doing something wrong?
I have the Meguiars DA polisher DVD and have watched it several times and follow the steps religiously. But I still wonder if there is something I'm missing?
