Results 1 to 8 of 8
Thread: Ultimate Polish-SMAT
  1. #1
    Registered Member
    Join Date
    May 2009
    Location
    Lancaster, CA
    Posts
    68
    Rep Power
    5
    Cool Ultimate Polish-SMAT
    Is any one can provide me with answer for this question: what is the cleaning/cut scale for UP from scale 1- to 10.
    Thanks to all
  2. #2
    Registered Member
    Join Date
    Aug 2010
    Location
    Fairmont, MN
    Age
    69
    Posts
    879
    Rep Power
    11
    Re: Ultimate Polish-SMAT
    From my notes...looks as if it's about a "3."
    Bill
  3. #3
    Administrator Michael Stoops's Avatar
    Join Date
    Oct 2004
    Location
    Trabuco Canyon, CA
    Posts
    15,709
    Rep Power
    1074
    UP is derived from M205, which is rated a 4 on the professional cut scale. But UP doesn't have the same abrasive load and it's really designed for hand or DA use, so it's relative cut is probably closer to a 2.
    You have to remember, however, that the cut scale on the pro products takes into consideration the intended use of the product. For example, M105 is rated 12 but that's when used with a wool pad and rotary buffer. If you use M105 on a DA with a polishing pad at low speed with light pressure it won't cut as much as it does on a wool pad/rotary. And M205 has been used with microfiber pads on the Rupes 21mm tool and it cuts like crazy. So any cut number needs to be put into proper context.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Please post technical questions directly to the forum rather than emailing or PM-ing me. You
    will get a faster response on the forum, and your question could help someone else, too!
  4. #4
    Registered Member
    Join Date
    May 2009
    Location
    Lancaster, CA
    Posts
    68
    Rep Power
    5
    That is very interesting!! so if I used M205 or UP with finishing (very soft) pad on DA with no pressure than I will get only, hypothetically, very glossy surface if i working the product for amble time; is that wright.
  5. #5
    Registered Member
    Join Date
    May 2009
    Location
    Lancaster, CA
    Posts
    68
    Rep Power
    5
    I forget to ask when M205 used with MF and Rupes 21 is the MF was cutting or finishing pad? Thanks Mike
  6. #6
    Join Date
    Oct 2004
    Location
    Pittsburgh, PA
    Age
    32
    Posts
    18,014
    Rep Power
    219
    Yeah, you would mostly be removing any dirt and spreading the polishing oils over the surface, not working on any defects.
  7. #7
    Registered Member
    Join Date
    Jan 2007
    Posts
    27
    Rep Power
    7
    At what point, or what buffer/pad combination, produce cut from Ultimate Polish?
  8. #8
    A proud Meguiar's Detailer! Please Wash Me Detailing's Avatar
    Join Date
    Jul 2011
    Location
    Rancho Santa Margarita ca 92688
    Age
    45
    Posts
    1,192
    Rep Power
    13
    the moment you put it on the paint. and it's a polish so the "cut" is minimal, use a compound if you want cut.
Thread Information
Users Browsing this Thread
Similar Threads
  1. To SMAT or not to SMAT - Recommendations wanted
    By cardaddy in forum Consumer Line
    Last Post: Nov 26th, 2012, 11:51 AM
  2. Ultimate Polish + Ultimate Black + NXT 2.0 = Happy Mini
    By cydewaze in forum Show Off Your Latest Detail Work
    Last Post: May 25th, 2012, 06:12 PM
  3. Deepest shine: Deep crystal polish or ultimate polish ?
    By aqueelmole in forum Detailing 101
    Last Post: Jan 18th, 2012, 06:00 AM
  4. Replies: 4
    Last Post: Aug 26th, 2011, 05:37 AM
  5. Ultimate Compound + Ultimate Polish vs M105 + M205
    By SaiyanZ in forum Detailing 101
    Last Post: Jan 6th, 2011, 03:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
