Results 1 to 10 of 12
Thread: Blush or Hazing with Ultimate Liquid Wax
    Jan 2010
    Coastal Texas
    6
    4
    I've been using ULW for about a year now - I like its luster and longevity but find that several hours after application that a blush or haze forms. On my Arctic Silver Porsche and Alpine White BMW 328i, the effect has been only slightly noticeable owing to the light colors. Last week I replaced my white Bimmer with a brand new Jet Black one which I polished with ULP then waxed with Ultimate Liquid Wax. The car looked perfect initially, but within a few hours a splotchy blush appeared; it's easily removed with a light wipe of a microfiber towel but reappears quickly. In the coatings world, blush often is due to the migration of low-molecular-weight species that fail to cure into the polymer matrix of the coating and migrate to the surface. Is the haze I see on my cars analogous? What might I do to eliminate or diminish this behavior?
    32
    18,105
    220
    Re: Blush or Hazing with Ultimate Liquid Wax
    Can you mention how you have been applying it?
    Jan 2010
    Coastal Texas
    6
    4
    I apply the stuff by hand to the entire car prior to buffing. I don't remember seeing this phenomenon last fall (when it's far cooler and less humid around here); perhaps environmental influences are at work or, since I'm working with the same bottle, the product has deteriorated.
    32
    18,105
    220
    It almost sounds like you are missing some residue as you are buffing it off.
    I usually buff off the Ult. Wax with a damp cloth followed by a dry one, and seems to go pretty easily.
    Trabuco Canyon, CA
    15,893
    1075
    The product can be a bit sensitive to temp and humidity and we're finding that you can almost always alleviate this issue by applying it to a panel at a time and then wiping off almost immediately. As you've noticed, the issue is easier to see on darker colors, but this short duration dry time should fix the problem.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Jan 2010
    Coastal Texas
    6
    4
    Thanks Michael. I'll use that approach the next time I try ULW. However, since the haze/blush has reappeared relentlessly for the last 5 days (the car is only a week old), I plan to wash the car thoroughly tomorrow and apply good ol' NXT 2.0, which - if I recall correctly - has sufficient cleaner to remove the "old" wax and still leave a nice shine. Based on my earlier, "low-humidity" experience with ULW, I'll experiment with it again, but for now, I simply want my new car to look . . . . . new.
    Jan 2010
    Coastal Texas
    6
    4
    I took a different approached than that described above. I simply washed the car with car wash soap and - of course - water and dried it with microfiber towels. Washing removed the haze and it has not reappeared after 7 or 8 hours; perhaps migration of fugitives was complete a week after waxing, washing extracted whatever species produces the effect or (and I hope this is not the case) weather conditions lacked the combination of heat and humidity that causes the issue. I recall that with my Boxster, which is never driven in the rain thus is washed relatively infrequently (I "dust" it with UQD once or twice a week), the hazing phenomenon ended about a week after waxing.
    In any case, I just gave the car a coat of UQD and it looks great, at least for now.
    BMW Nut smack's Avatar
    May 2010
    Las Vegas Nevada
    909
    Quote Originally Posted by SailorMan View Post
    Im with you on the NXT 2.0. It is pretty bubba proof and gives outstanding results. The Ultimate wax on the other hand is finicky but gives even greater results. Just comes down to how willing you are to get that extra pop.
    Practice dosent make perfect, the dedication to achieve pefection makes perfect. "Smack"
    2011 Jet Black 328i Touring
    2007 Jet Black 335i Sedan
    1999 Blue Metalic Camry
    Dec 2009
    Iowa
    2,309
    30
    A couple of comments. After using ULW for a year and still getting blue haze, I can understand your frustration. And now that you've added a black car to the fleet you may need a DA buffer. Makes everything easier and you can put ULW on so thin, which may help.
    David
    Aug 2010
    Fairmont, MN
    69
    896
    One thing I discovered (from reading here on MOL), was to do the vehicle in sections.
    I do half the hood, do the other half, then wipe off the first half. Do a fender, go back and wipe off the other hood half...on and on.
    After one go around, I repeat the process. Not so much as to apply a second coat, but to insure that I haven't missed any spots.
    If I do get some blushing (actually from NOT removing all of the product), a quickie wipe with UQD on a MF, takes care of it.
    I DO use a DA to apply UWL...so thin that you really can not see it.
    Just my results...
    Bill
  1. Replies: 13
    Last Post: Jul 1st, 2012, 04:10 AM
  2. Ultimate Wax Liquid, Ultimate Wax Paste
    By RPPM in forum For Sale or Trade
    Last Post: Aug 29th, 2011, 05:21 PM
  3. New to Ultimate Liquid Wax
    By mis3 in forum Detailing 101
    Last Post: Aug 7th, 2011, 01:03 PM
  4. Ultimate Compound, Single Stage Paint, & Hazing
    By ge0rge in forum Detailing 101
    Last Post: Jun 6th, 2011, 03:55 PM
  5. Ultimate Quick Detailer Hazing....
    By pcmark in forum Customer Service Hotline
    Last Post: Jan 9th, 2008, 05:28 PM
