Results 1 to 10 of 10
Thread: Windshield Wiper Arm Painting
  1. #1
    Registered Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    60
    Rep Power
    2
    I looked around on the forum and found nothing on this topic. But I was wanting to give a little attention to my wiper arms. They are dull and on one the black paint has come off in a section. My concern is that we pay alot of attention to the shine and protection of the paint(which is important), but non to the lone visible windshield wiper arms. I know that since you read this thread you will take a second glance at them.
    But my question is what type of paint do you guys think will adhere better to it. I think taking the arm off the car is better due to overspray. But if anybody have done this please advise.
  2. #2
    Registered Member BillyJack's Avatar
    Join Date
    Jun 2010
    Location
    Pittsburgh, PA
    Posts
    424
    Rep Power
    9
    Re: Windshield Wiper Arm Painting
    The set that's on my Camino now was painted with satin black engine paint from the auto parts store. They've held up well, having been done 3-4 years ago, but my Camino's a garage queen. I've seen and heard good things about both Eastwood's Satin Black Engine paint and POR-15 Black-Kote product, but haven't used either. As it is with all paint projects, the results usually reflect the attention to detail in the prep work.
    Bill
  3. #3
    Registered Member
    Join Date
    Oct 2006
    Location
    Blue Springs, MO
    Age
    56
    Posts
    344
    Rep Power
    10
    Another set of questions in this realm are involved with are you doing this for a long term result or to make something look better on a vehicle you are cleaning up to flip?
  4. #4
    Registered Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    60
    Rep Power
    2
    Quote Originally Posted by agp56 View Post
    Long term. Cars are too expensive now a days to flip. Just take care of what you got and it will take care of you.
  5. #5
    Registered Member erobertson's Avatar
    Join Date
    Dec 2007
    Posts
    80
    Rep Power
    6
    Most wiper arms are easily removed and I would recommend painting them off the vehicle. Duplicolor makes spray paint that is suitable and which can be purchased at most any auto supply store. I painted mine a matt black but there are other choices. Short quick bursts while moving the can sideways works best. Try to avoid runs by only applying thin coats. You will need at least two thin coats. Be sure to sand off any rust or loose paint prior to the repaint. For just a few bucks this is a easy fix for those less than perfect wipers. You will need to wait about 30 days prior to apply other treatments to the arms like sealant, wax etc. to allow the paint to fully cure. Good luck this is a very easy project!
  6. #6
    Mr. greg0303's Avatar
    Join Date
    Nov 2009
    Location
    Brooklyn New York
    Posts
    2,584
    Rep Power
    39
    Once you get your wiper arms repainted the easiest way to clean them up in the future is with a steamer. Select the proper nozzle size and keep steam away from rubber. Hot steam even removes a product splatter in no time.
    Thanks to Renny Doyle I learned this approach during Detail Fest 2012. It's a time saver and very effective.
  7. #7
    Boss 300 Scott's 62's Avatar
    Join Date
    Oct 2010
    Location
    Sacramento California
    Posts
    272
    Rep Power
    5
    I did my Hondas wiper arms a couple years ago I sand blasted them and painted them satin black it made the car look so much better. They still look good today
  8. #8
    Detailing my Black VW
    Join Date
    Apr 2010
    Location
    UK
    Posts
    404
    Rep Power
    8
    A word of warning be careful removing them from your car.
    On one of my old Peugeots I needed to use an extraction tool. Or risk cracking my screen.
    I went to my local windscreen centre and asked if they would remove them.
    I sanded mine down. Then for a base coat I used a rust treatment paint that turns black when dry.
    Gave it 24hrs followed by a light sanding of 3000 grit.
    I then sprayed with a heavy duty metal paint. They looked great 10yrs later.
    Hope that helps.
  9. #9
    Just Some Dude
    Join Date
    Apr 2010
    Location
    State of Confusion
    Posts
    48
    Rep Power
    4
    Last year I was wondering what to do with my wiper arms as well. Not having any paint, but having a bottle of Ultimate Compound, I removed the arms from the car and then the blades from the arms. After I cleaned them, I rubbed some Ultimate Compound on them by hand and the results were great.
  10. #10
    Registered Member
    Join Date
    Aug 2006
    Location
    Orange County, CA
    Posts
    251
    Rep Power
    9
    I've repainted numerous wiper arms - I really like SEM Trim Paint (satin finish) because it is easy to apply, leaves an even appearance, and is very durable.
    I remove the wiper arms from the car, wash them, bead blast or sand them, wash them again, and then paint with SEM Trim Paint.
    Andy W.
    Bimmers - '72 Tii, '74 Tii, '88 M3, '89 E30 - S52, & '01 330i
    Ford - '91 Ranger
Thread Information
Users Browsing this Thread
Similar Threads
  1. What to use on wiper blades?
    By FullyFamous in forum Detailing 101
    Last Post: Aug 16th, 2010, 01:27 PM
  2. Clearing Windshield Wiper Marring
    By xantonin in forum Detailing 101
    Last Post: Jun 4th, 2009, 01:07 PM
  3. Do you dress your windshield wiper arms?
    By akimel in forum Detailing 101
    Last Post: Oct 7th, 2008, 01:07 AM
  4. Wiper Blades... What do you use?
    By gb387 in forum The Break Room
    Last Post: Apr 18th, 2006, 05:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
