Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Carpet Cleaning with Extractor...
  1. #1
    Registered Member ChevyNick's Avatar
    Join Date
    Sep 2011
    Location
    Michigan
    Posts
    414
    Rep Power
    6
    Hey guys. I'm trying to learn how to clean interiors really well, not just remove floor matts, treat them with Simple Green or APC, scrub, and hose down, and let dry in sun. I bought a Bissell Little Green Machine Auto version and the suction just wasn't there. Long story short, I went and got a rather powerful extractor from my grandparents house. Now, it does have the ability to not only extract, but squirt water out as well. But it is an inconvenience to me to hook it up because it appears the thing will only hook up to a sink faucet. I suppose I could look for some type of adapter maybe to hook it up to a garden hose? I really would like to know if there is another method though for cleaning carpet using only the extractor part of the machine.
    Today I had a spray bottle of simple green and a spray bottle of water I've got a scrub brush as well obviously. So I sprayed the carpet with simple green, then sprayed some water on there to get it wet enough to the point where I can effectively scrub the carpet. Then I extracted that out, then I continued to squirt the carpet with the spray bottle of water until the water coming up through the extractor was no longer foamy.
    #1) Is that a good process or is there something better?
    #2) Can anyone recommend a carpet shampoo that works well and leaves a nice fresh scent behind?
    Always searching for the best.... Keep it country!
    SkiDoo Snowmobiles!
  2. #2
    Registered Member ricadodetail's Avatar
    Join Date
    Aug 2011
    Location
    Los Angeles
    Posts
    82
    Rep Power
    2
    U cannot and should not use simple green only. Its a degreaser use it for tough stains and not alone it can damage the fibers and color. Regular carpet soap, or detergent is safer. Just dont use too much of it because the left over soap will attract more stains. Use just enough soap some simple green to get out heavy stains and hot water. Just my two cents.
  3. #3
    Serious Clean Showmob's Avatar
    Join Date
    Jan 2012
    Location
    Bend Oregon
    Posts
    138
    Rep Power
    3
    Here is what I do when cleaning carpets.
    1. Mix solution and prespot heavy stains/oil based stains
    2. Wet carpet to be cleaned, I have a mytee extactor with a solution tank so its all with a trigger. You don't need to fully soak the carpets.
    3. Brush carpet and scrub stains
    4. Vac out soiled solution.
    5. Re treat heavily soiled areas if needed.
    To answer your question about a shampoo I really like Malco xtracts and xtracts prespotter. Both smell nice and will not attract grime back.
    Even the best cars look like junk when they are not clean
  4. #4
    Join Date
    Sep 2011
    Location
    Michigan
    Posts
    414
    Rep Power
    6
    Ok thanks to both of you guys. Good thing I practiced on the family grocery getter first haha :P.
    Do either of you have experience using Zep extractor shampoo? I have heard some good things about it and am going to try it this weekend. I really prefer if I can get a product locally as opposed to buying online.
    SkiDoo Snowmobiles!
  5. #5
    Registered Member
    Join Date
    Aug 2010
    Location
    Fairmont, MN
    Age
    69
    Posts
    883
    Rep Power
    11
    Re: Carpet Cleaning with Extractor...
    If you are looking for shampoo(s) etc...do you have a janitorial supplier near by? If so, give them a call or just stop by and see what they have to offer. They are the pros when it comes to cleaning 'stuff.'
    Other than getting out as much liquid as possible, make sure things are DRY before you button everything up. You can't believe how quickly mildew can develop.
    Bill
  6. #6
    Join Date
    Sep 2011
    Location
    Michigan
    Posts
    414
    Rep Power
    6
    Ok good idea bill. In fact I have to go to a janitorial place tomorrow at work. When I'm there ill have to ask them real quick.
    SkiDoo Snowmobiles!
  7. #7
    Join Date
    Jan 2012
    Location
    Bend Oregon
    Posts
    138
    Rep Power
    3
    I haven't used their shampoo but I've used some of their other products and they worked fine.
  8. #8
    Registered Member
    Join Date
    Nov 2012
    Location
    usa
    Posts
    1
    Rep Power
    1
    Now-a-days, Various companies are introduced many kinds of products with up-dated features. Carpet cleaning, for beautification and the removal of stains, dirt, grit, sand, and allergens can be achieved by several methods both traditional and modern. Where to find best and reliable carpet cleaning with extractors ?
  9. #9
    is more old fashioned Tuck91's Avatar
    Join Date
    Jan 2009
    Location
    New Lenox, Illinois
    Posts
    10,180
    Rep Power
    292
    I just picked up a new Aztec Hot Rod Water Extractor, its a pretty good unit.
    Registered Member
    Join Date
    Oct 2012
    Location
    Twin Cities, MN
    Posts
    49
    Rep Power
    1
    I have the Aztec also. Having smaller tanks makes you have to refill often and wait for water to heat up for really dirty interiors. Other than that, I love it for being mobile. Nick if you don't mind, please PM me the products you use and normal process. I don't use it often and want to improve my method. I spray the whole area with APC+ and was told not to put anything but water in the solution tank.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Turn A Shop Vac into a Carpet Extractor???
    By The Wash Doc in forum Detailing 101
    Last Post: Jun 22nd, 2011, 02:45 PM
  2. Shop Vac or Extractor for carpet Cleaning?
    By Ravi_1992 in forum Member Polls
    Last Post: Apr 16th, 2011, 11:01 AM
  3. Carpet Extractor Opinons
    By tapp1 in forum Detailing 101
    Last Post: Feb 23rd, 2011, 07:13 PM
  4. EDIC Bravo carpet extractor $320
    By Joe's detailing in forum For Sale or Trade
    Last Post: Jun 14th, 2009, 08:41 PM
  5. Where to get new wand for carpet extractor
    By JeepZJlover in forum Detailing 101
    Last Post: Dec 22nd, 2004, 05:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
