Results 1 to 10 of 17
Thread: Headlight Protectant
    Registered Member MarkFilgerleski's Avatar
    Oct 2011
    Hanscom Air Force Base, Massachusetts
    126
    3
    Finally picked up some HP as my local Wal-Mart has finally started carrying it.
    I started off claying my headlights to remove the Ult. Wax I had been using on them. I then followed with PlastX.
    On to the HP. I applied about a quarter -sized amount onto a MF towel. Dabbed it evenly in spots over the headlight, and then worked the product "in" to the plastic. I ended up using WAY too much product. It was a pain to buff off. Much like my first experience with ULW on a black car .
    After some huffing and puffing, I finally buffed off the remaining product. I was left with an extremely slick feeling headlight. Definitely left my headlights slicker than ULW did.
    On the other headlight, same results, just an easier process, as I used about a dimes worth of product.
    Can't really comment on the effectiveness of the product, obviously, However, the slickness of the plastic seemed to be very tactile evidence of the protection left behind, IMHO.
    Thanks for reading!
    Cheers,
    Mark
    Nov 2010
    Vancouver
    918
    12
    Re: Headlight Protectant
    Hmmm great bit of info, i plan on using this on my cars soon....thx for the tip!!
    "STRIFE" aka Phil
    2003 Mazda MPV LX (Metalic Green) (wifey's)
    Meguiars Indonesia Admin
    May 2011
    Jakarta, Indonesia
    136
    4
    do we need to wait for +- 30 to cure like we did when waxing ? or it just wipe on wipe off product ?
    Thanks
    Aug 2004
    Glendale, AZ
    29
    2,796
    41
    I have this but haven't tried it yet. I'm curious if it lasts longer than a traditional wax.
    Trabuco Canyon, CA
    15,893
    1075
    Quote Originally Posted by PhantomMagician View Post
    Thanks
    No, it's more a wipe on, work in, wipe off - more like a pure polish application than a wax application.
    Quote Originally Posted by Marc08EX View Post
    Yes, much longer and with far greater UV protection as well.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Nov 2006
    HOUSTON, TEXAS
    393
    bookmark.
    May 2011
    Australia
    93
    3
    Im assuming this product in no way affects the appaearance of the headlight? just provides protection??
    Mar 2012
    Key West Florida
    40
    Quote Originally Posted by MarkFilgerleski View Post
    I ended up using WAY too much product. It was a pain to buff off... the slickness of the plastic seemed to be very tactile evidence of the protection left behind
    During application I felt like I couldn't put on too much. The haze was always slight.
    Given the smell, the look, and feel it reminds me of sunscreen!
    After application, the surface is really slick. It's been my experience the slickness lasts through two washings, with some rain inbetween.
    Oct 2011
    126
    3
    Quote Originally Posted by LS1BERLINA View Post
    Maybe adds some slight glossiness to the headlight....simply beacause product is on there. Could be "placebo" though.
    Mark
    Mar 2012
    Key West Florida
    40
    This one bugged me because based upon my experience with the product my reaction was "no way" and yet your experience was different, way different. So, I experimented; 2 ways. First on headlights that needed repair. My hypothesis being that maybe the dryness of the lens was to blame. I applied non Meguiars scratch remover, thinking it wouldn't add replenishing oils. No matter how much HP I added (to 1 headlight) removal was always a snap. Next, I guessed maybe the set time duration was the culprit. So, on two headlights, 1 nonM's prep (see above) one prep'd with Plastx ( 2 coats), I worked in sections applying what felt light the same heavy dosage (blotting 1.5mm thickness) to each headlight. I removed the HP after increasing 10 minute increments. I found that in deed after 20 minutes removal becomes increasingly difficult. At 40 minutes, the end of the test, removal required heavy force to remove. Both headlights performed the same. The test was run in my garage with all doors closed, but outside was roughly 60 degF and 40% RH.
    I can't say how the environmental conditions affect the removal process because they weren't tested. I'm sure they do though.
    Bottom line: letting HP sit on the lens is not a good idea, it'll make removal way more difficult.
  1. Headlight Protectant
    By Michael Stoops in forum 2012 New Products & Improved Products
    Last Post: Mar 18th, 2013, 10:44 PM
  2. Question About Headlight Protectant
    By David Fermani in forum Clear Plastic Detailing
    Last Post: Feb 24th, 2011, 09:44 AM
  3. Headlight Restoration fpr My Car
    By G_S_DB in forum Show Off Your Latest Detail Work
    Last Post: Apr 17th, 2010, 03:23 PM
  4. Headlight?
    By Fancy Images in forum Clear Plastic Detailing
    Last Post: Apr 11th, 2008, 10:10 AM
  5. Wax on headlight lenses?
    By poerboy in forum Detailing 101
    Last Post: Jun 4th, 2005, 07:26 PM
