clear coat safe rubbing compound function - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: clear coat safe rubbing compound function
  1. #11
    Sep 2005
    Sydney, Australia
    4,274
    62
    Re: clear coat safe rubbing compound function
    Quote Originally Posted by WeekendGlaze View Post
    Don't forget to use some type of polish cleaner before waxing because polish leaves behind oils that will cause the wax to not bond with the paint.
    This is generally not required, and definitely not required if using a Meguiars polish followed by a Meguiars wax.
  2. #12
    Feb 2012
    los angeles CA
    8
    7
    any comments on using swirl remover after rubbing compound to polish?
  3. #13
    37
    18,959
    233
    Well, the things milder than the Rubbing Compound would be things like the Polishing Compound, SwirlX, Ult. Polish, #9 Swirl Remover and some others...
    They wouldnt be needed after the Rubbing Compound unless some fine marring was left behind.
    You would be just as well to use them for your regular detail next time. They'll have a little more polishing oils than the Rubbing Compound, but nothing that needs that much more time/work right away.
  4. #14
    Trabuco Canyon, CA
    21,324
    1135
    The "clear coat safe" part about our Rubbing Compound means that it won't scour the paint like some old school rubbing compounds often do. Still, it is designed to be the initial, heavier cutting part of what is generally a two part process. Part two here would be the use of our Clear Coat Safe Polishing Compound. The primary difference between these two is the amount of cut offered. Because the Rubbing Compound has more cut and is designed to remove the more severe defects, you'll be using more energy (ie elbow grease) to work it in than you will with the Polishing Compound. In both cases you'll want to use a soft foam wax applicator pad rather than any sort of cotton terry cloth applicator.
  5. #15
    Feb 2012
    los angeles CA
    8
    7
    Thanks for the details, my car is 2 years old, the paint condition is not that bad, just some fine swirls and scratches, and it is a black car, so should i still use rubbing compound on my whole car? i'm planning on using cleaner wax as a polisher after, and then wax it again with gold class plus, any thoughts on that?
  6. #16
    37
    18,959
    233
    If the paint needs it, it needs it.
    You could try the Polishing Compound first.
    The Cleaner/Wax wont do much to remove swirls/marring, so you still may need both.
    In the future, Cleaner/Wax followed by wax is a great detail.
  7. #17
    Trabuco Canyon, CA
    21,324
    1135
    Truer words were never spoken....er, typed.
  8. #18
    Feb 2012
    los angeles CA
    8
    7
    So after all of your helpful advice, I'm finally going to start detailing my car tomorrow (wash, dry, clay, rubbing compound, cleaner wax, gold class liquid wax), but i just realize another problem..my car is parking outdoor since I'm living on my own in a small apartment, and I know that I'm not gonna be able to finish all those steps in one day, so i will have to leave my car out there overnight....i was thinking if it is okay to use the ultimate quik wax after clay barring, let it sit outside for one night, and then i will start with ultimate quik detailer the next day before polishing....
  9. #19
    37
    18,959
    233
    No need to use the UQW in beteen. Just QD or UQD in the morning.
    Just in case, UQD is not for claying.
    Wash / Clay is pretty quick, hopefully can try out some polishing while at it.
  1. Used polish compound on clear coat
    By boatuser41 in forum Detailing 101
    Last Post: Jul 27th, 2012, 08:07 PM
  2. M105 Ultra Cut Compound - Clear-coat paint safe???
    By Vettefan in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: Dec 3rd, 2011, 02:59 PM
  3. Difference between scratchx, swirlx, colorx and clear coat safe rubbing compound ?
    By svtstangcobra in forum Consumer Line - Product Discussion
    Last Post: Aug 30th, 2011, 02:42 PM
  4. Meguiar cleaner wax - safe to use on clear coat every month?
    By illyas2k in forum Consumer Line - Product Discussion
    Last Post: Jan 11th, 2010, 10:28 AM
  5. Safe on NON clear coat ?
    By Show It in forum Consumer Line - Product Discussion
    Last Post: Mar 4th, 2004, 02:23 PM
