Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Ultimate compound
    Nov 2011
    Southwest Minnesota
    141
    3
    Ultimate compound
    How many passes of uc by hand should it take to remove swirls. Just bought it the product seems to work fine but it was a little cold today so maybe warmer weather will make it easier. I did notice that i does leave a little haze which it was said not to , but followed with ultimate polish and it removed any haze that was there.
    Registered Member Mark58's Avatar
    Mar 2011
    Erie PA
    66
    650
    9
    Re: Ultimate compound
    In my opinion it is almost next to impossible to remove all the swirls by hand. Yes it can be done, but before you are finished you will be getting a DA polisher.
    Sep 2005
    Sydney, Australia
    2,084
    35
    Quote Originally Posted by polaris View Post
    That's almost impossible to answer. It depends on the severity of the swirls, how hard/soft your paint is, how you're applying / working in the UC etc etc.
    If you're hazing the surface by hand, that would indicate your paint might be a little on the soft side, so you may be able to remove the swirls with just one pass!
    Did it look like they were gone when you were done?
    Nov 2011
    Southwest Minnesota
    141
    3
    They are gm cars the one it did not like the swirls were completely removed the other car that i tried it on is outside and was dark once i was done so cant tell if the swirls are gone and im working by hand.
    Trabuco Canyon, CA
    15,666
    1073
    Very well said! The variables are almost infinite.
    Even though both are GM vehicles the paint can be quite different on them. Different factories, different model years, etc are just more variables in this hobby. What are you using for an applicator? We would discourage the use of cotton terry cloth since that material alone can be quite aggressive on the paint and inflict a lot of swirls regardless of the liquid paired with it. A soft foam wax applicator pad is your best bet here.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Nov 2011
    Southwest Minnesota
    141
    3
    A microfiber applicator is what im using just tried some on the pillars and got some grayish,blackish residue on the pad should i be concerend or is this a sign that the products is working.
    Sep 2005
    Sydney, Australia
    2,084
    35
    Is the vehicle gray / black? If so, it's probably got single stage paint and what you're seeing on the pad is normal.
    How old is the vehicle? Make / model? I ask because someone here may know whether your type of vehicle has single stage paint or not.
    BTW the microfiber applicator is probably the cause of your hazing. If you switch to foam applicator pads, you'll probably eliminate or improve the hazing.
    Nov 2011
    Southwest Minnesota
    141
    3
    2008 grand prix black but area has not been clayed before either.
    Nov 2011
    Southwest Minnesota
    141
    3
    [IMG]www.polariscarpics.com[/IMG]
    Nov 2011
    Southwest Minnesota
    141
    3
    Here are some pics of the pillars.Just click on the pics to get a larger image.
  1. Replies: 2
    Last Post: Sep 3rd, 2011, 07:16 PM
  2. Replies: 4
    Last Post: Aug 26th, 2011, 05:37 AM
  3. New to Ultimate Compound and Ultimate Polish
    By 05RLS2 in forum Consumer Line
    Last Post: Jul 20th, 2011, 10:12 PM
  4. Ultimate Compound + Ultimate Polish vs M105 + M205
    By SaiyanZ in forum Detailing 101
    Last Post: Jan 6th, 2011, 03:29 AM
  5. Ultimate Compound
    By HealthyCivic in forum Consumer Line
    Last Post: Oct 12th, 2010, 10:06 AM
