Re: Home brews
If your goal was to use something for use as a daily wipedown that leaves something behind I would stick to LT. While it doesnt leave protection down for say it does leave a slick silicone finish that repels water and if you are using it daily that repellency would be replenished. The fact of the matter is, using something like m135 daily is not feasible. Layering on m135 daily doesnt continue to enhance anything. There is no true building of product or gloss. That is what the wax is for. In addition, LT outshines m135 in cleaning ability which is an important factor to take into consideration when you are doing daily wipedowns.
The added lubricity in LT will help reduce your chances of marring from wiping dust and dirt. However, I would encourage you put the QD's down and save it for after washing, for use on a clean surface. The more you touch your paint the higher the chances of you instilling scratches. You're vehicle is white so you might not notice it but on a black car, it would be very apparent.
