Crayon scratch repair
Results 1 to 10 of 20
Thread: Crayon scratch repair
    Aug 2005
    5
    I have a 2008 red Ford Focus. The paint on the passenger side all along the car length has a series of fine scratches from being rubbed by a bush when
    pulling the car out of the garage. The paint is scratched down to the white primer coat in most places and is very noticeable. There are too many lines to use a paint stick on, my fear is that this will make it look worse also. I don't have the $500 plus that a body shop quoted me to fix this. I started thinking about filling the lines in with a crayon, to at least make the white primer less noticeable. I bought an 84 crayon box to get the most variety of colors to match the paint. Of course the basic red was the best match. I rubbed the crayon over the scratch lines at an angle and rubbed lightly with a soft cloth. To my amazement, it made all but the deepest scratches almost unnoticeable. My question is, what would you recommend to make my fix last as long as possible? I know this is no way permanent, but even if I have to reapply every couple of weeks (it took me all of 5 minutes to do this) it is worth it to me. Is there a product, short of a clear coat reapplication, that will maximize the longevity of my fix?
    Thanks,
    Karen
    PS I could post a before/after picture if anyone would like to see the results.
    Registered Member Bjkearns's Avatar
    Jun 2010
    Orange County
    321
    Re: Crayon scratch repair
    pictures would help please
    Registered Member mswerb's Avatar
    Cleveland, Ohio
    44
    148
    9
    I'm sorry, did you say you bought a box of crayons????
    I guess there is a first time for everything. Please posts pictures of this.
    Aug 2005
    5
    Okay, here are some pics. Unfortunately I didn't take any before pics of the main area, but I did the same treatment on some other minor scratches
    and am posting them.
    Let me just say that the repair is far from perfect. It appears to work best on shallow, narrow scratches. I think what it mainly does is cover the white primer so that the scratch doesn't stand out nearly as much. My close-up shots look worse than the car does because the effect is best when viewed a bit at a distance. I tried to do the before and afters at the same angle as to not add any artifacts such as glare or reflection.
    I hope my upload works, never did this before. IF not, I made the photobucket album public so you can always follow the links.
    http://i685.photobucket.com/albums/v...passbefore.jpg
    http://i685.photobucket.com/albums/v.../passafter.jpg
    http://i685.photobucket.com/albums/v...rearbefore.jpg
    http://i685.photobucket.com/albums/v...rrearafter.jpg
    http://i685.photobucket.com/albums/v...per1before.jpg
    http://i685.photobucket.com/albums/v...mper1after.jpg
    http://i685.photobucket.com/albums/v...esideafter.jpg
    Registered Member ChevyNick's Avatar
    Sep 2011
    Michigan
    416
    Crayons?? Really lol? Maybe just wax right over it and it'll preserve the crayon a little longer? Be careful when removing wax from the crayon because you might just wipe that off to.
    Always searching for the best.... Keep it country!
    SkiDoo Snowmobiles!
    Cleveland, Ohio
    44
    148
    9
    You say these were caused by a bush?!? I can't picture a bush causing vertical scratches that deep.
    Trabuco Canyon, CA
    21,324
    1135
    Talk about thinking outside the box - the 84 color box at that!!
    As you obviously know, this is going to be very short term at best and there probably isn't really much of anything you'll be able to do to dramatically prolong this crayola correction. Waxing over the crayon filler probably won't do a whole lot; the film of wax left behind is incredibly thin so it's not like wrapping the finish in plastic or something, and odds are even with some gentle washing you'll end up removing much of the crayon filler fairly quickly anyway.
    While paint touch up is possible here, it's tedious at best and without proper knowledge of sanding and buffing to smooth out the paint, you often end up trading one less than attractive problem for another. $500 actually sounds a bit low to repaint the whole side of the car, or even just a couple of panels, considering the prep that needs to be done for scratches down to the primer. That means it's either a good deal, or a bit worrying - how good a job will they do for that kind of money?
    So, do you keep applying the crayons every so often? Do you pick up an artists paint brush and some factory touch up paint and, with a very steady hand, touch up the spots a bit more permanently? Or do you just let it go and tighten your money belt a bit for a few months in order to save up the $500 to get it professionally corrected?
    Aug 2005
    5
    Quote Originally Posted by mswerb View Post
    Yes, evergreen bushes next to the driveway. Actually, they are horizontal scratches. Makes me think Ford did a lousy paint job on the Focus with inadequate thickness of paint. But anyway.
    Well, it's been over two weeks and the car still looks infinitely better than before. I am satisfied with my repair, and like Michaels says, unless I save up the money to do the repair properly, this will have to do.
    Cleveland, Ohio
    44
    148
    9
    The 1st and 2nd pictures you posted show BOTH horizontal AND vertical scratches. Seems fishy. HMMMM.
    Aug 2005
    5
    I suppose there are a few vertical scrathces in the paint as well, but the majority are horizontal.
    What do you mean by fishy? Are you saying I'm lying about how the scratches got there? What possible reason would I have?
  1. Wet sand scratch repair
    By THE BIG BUFFER in forum Show Off Your Latest Detail Work
    Last Post: Jun 22nd, 2010, 10:38 AM
  2. My First Chip and Scratch repair!
    By meehan in forum Detailing 101
    Last Post: May 27th, 2009, 12:56 PM
  3. oxidizing scratch repair
    By DoctorWho05 in forum Detailing 101
    Last Post: Mar 26th, 2009, 05:02 PM
  4. Been playing around with scratch repair....
    By Nick Chapman in forum Show Off Your Latest Detail Work
    Last Post: Feb 7th, 2008, 09:33 PM
