Every time when I use Ultimate Quik Wax, it leaves dark streak marks. So what am I doing wrong? I 'm not spraying a lot onto the car. I spray a little, spread it around with a microfiber towel and then wipe it off with the other side of the towel. Any advises?
What am I doing wrong?
Re: What am I doing wrong?
I experience that problem when I try to use only 1 microfiber towel. It's mainly coming from the dampness of the towel with the UQW that's left in it. The solution to the problem is to have a second and dry microfiber towel to wipe off the residue.
Hope this helps. Please let us know if this works.2011 Car Crazy Showcase SEMA Team
i just use a Megs even coat applicator pad to spread the UQW around a panel, and wipe off with a dry ss towel, works great"STRIFE" aka Phil
I do the same thing as Marc, for the exact same reason. Even lightly misting the car's surface, by the time I get about halfway done, the towel I use for application gets saturated enough that it won't completely absorb the excess wax. I'll usually use one MF for application, still turning to a clean side every couple of panels to minimize any chance of scratching, and one or two MFs for the final wipe, also turning to a clean side every couple of panels.
I suppose I take the opposite approach.
Once the towel is damp, I dont have to keep spraying as much. One trigger pull over the whole door, with the towel already damp, seems to come out good for me.2017 Subaru WRX Premium - WR Blue
Just to be clear, I get the streak marks when wiping it off, not applying, but thanks for the input. I'll try using a second towel to wipe off instead of using one. Come to think of it, when I first used UQW, I used 2 towels and since then I only been using one. So maybe that's why.
