Buffing single stage cured paint
Results 1 to 10 of 13
Thread: Buffing single stage cured paint
    Aug 2011
    Cairo, Egypt
    52
    7
    Hello
    Today I decided to detail my old Vectra for the first time
    It was repainted many many times since manufactured in 1995, and my guess that it has a pretty thick layer of paint & prime (havent measured that though)
    Paint color is dark blue, had severe cobwebs, many random light scratches, orange peel (although the paint is soft), and lost most of it's gloss already (looks pretty dull)
    Last paint job was done 6 months ago, so I'm pretty sure it's cured
    So, washed my car, dried it, clayed it with a mild clay bar and last touch, then started buffing...
    I started with a foam cutting pad, using #84, and a rotary buffer at speed 3.5
    I applied much pressure, and went through different passes in overlapping lines... Then I noticed that this combination was actually doing nothing
    However, the pad was colored in blue, so I knew that my car uses a single stage paint
    So, I decided to move up in the scale, and again, using a cutting pad, and #85, and some aggressive buffing
    I noticed a very slight enhancement
    So I finally moved to my wool cutting pad using #85, and started to buff aggressively...
    Only with that combination, I started to see some noticeable difference
    Cobwebs became fewer, and the paint started to shine again
    I continued with this combination for the rest of the hood, and the hood was somehow shinning (Had to reapply the compound to the pad for atleast 6 times using those X marks), with some cobwebs still existing, and the same orange peel appearance (although the paint was very soft and polished)
    I also noticed that the process left no swirl marks at all.... Although I expected from the wool pad to leave much
    Next, I started to go down the scale again to add more shine
    So I used a polishing pad, with #84... Which actually added nothing to what I already had
    So I knew that this is the best I can have
    Plenty of questions in my mind...
    1. Is claying really a mandatory step ?? The clay bar is somehow expensive, and the paint was soft before and after claying, and I really didnt notice any difference after claying, and the clay bar wasnt collecting any dirt
    2. Why didn't the wool pad leave any swirl marks ? I was using much pressure, and was moving slowly using #85
    3. Why is there still some cobwebs, although I used this aggressive combination... Do I need to move to #95 or #105 ??
    4. I always hear that single stage paints are easier to buff... Why #85 alone didnt do the job ?
    5. Why did the wool pad added gloss to the paint, rather than cutting through the paint ?
    6. Why I couldnt get some extra shine when I moved down the scale again to #84 and even #83?
    7. That stupid orange peel effect... I can see it but I can never feel it with my hand... The paint is really soft... Any way to remove it ?
    8. How to clean those colored pads ? I thought of using some thinner... Would that hurt the pad ?
    9. I'm consuming too much product during the process... Buffing only the hood needs at least 6 X marks... I reapply the product when I see that the old application is almost dry (both the hood and the pad), and I know that dry buffing is dangerous, so I reapply again... Is this normal ?? Is there a way to cut some costs here ?
    10. The surface was somehow hot when I started the process... Did that affect anything ?
    Sorry for the too much questions
    It's just that I want to understand everything and build my technique
    Thanks in advance !
    37
    18,971
    233
    Re: Buffing single stage cured paint
    You are in a hot/sunny environment, I would expect your paint to be a bit dry. (even though new, hard to say the quality). The dry paint will absorb more product. Although 6 X's for a hood doesnt seem too out of line.
    Not sure about the use of the wool pad/#84/#85, etc; have to let someone experienced chime in on those.
    But I would try to use a lot of polishing oils in the future when the paint is fixed up... something like #80 which is a mild cleaner/polish, or a pure polish like #7/DC Polish, to keep the paint moisturized. Then wax after of course.
    Trabuco Canyon, CA
    21,324
    1135
    Quote Originally Posted by asalah View Post
    Claying is really only mandatory if the finish needs it. While we would expect it to in your area, you would know better since you can get your hands on the car and we can't from here. If the clay wasn't showing anything being picked up, then that's a pretty indicator that you didn't much of a surface contamination issue
    Normally we would recommend only light to moderate pressure when using any pad on a rotary. Even so, we would expect to find some level of buffer swirl with M84/M85 on a wool pad. You mentioned a speed of 3.5 and we assume that's the dial setting of the buffer. Do you know what rpm this spins the buffer at? We would expect defect correction to happen in the 1400 rpm to 1800 rpm range, depending on the paint, pad, level of defect, operator skill, etc.
    Even though this paint is single stage, it is quite possible that it's very hard. How large or small an area were you working on each time? You should be confining your work area to no more than 2' x 2' (60cm x 60cm)
    Generally speaking, they are. But that also assumes you're talking about an older type lacquer single stage paint, and not a modern catalyzed single stage. Also, we anticipate that the paints you're using in Egypt are quite a bit different than what we use here in the States. We know that paints used in Europe are quite a bit different than what's used here, and in Asia they are different still.
    On some really hard paints you end up fairly easily smoothing out or almost burnishing the upper surface of the paint, yet you can't cut deep enough to remove the most severe defects. We've seen this first hand many times on very hard single stage white paint so we understand your frustration.
    Depending on the quality of the paint and the quality of the paint job, it may require wet sanding in order to bring out the maximum gloss. Now, please understand that we are not suggesting you start wet sanding this car, just making an observation here.
    We assume that by "soft" here you mean smooth and silky and not what we generally mean by the word "soft". As we use the term here in the States, a soft paint is one that's very easy to correct - not the situation you're faced with at all. But as for the orange peel, you're right - you can't feel this very fine texture but it does detract from the appearance of the finish. The only way to effectively remove it is to wet sand and then rotary buff. But that takes us back to the earlier discussion - we are not recommending that you wet sand as it is a very advanced process and things can go bad on you very quickly. But if the orange peel is that bad it may be a huge reason why you're just not able to get the ultimate finish you're looking for. Very glossy paint with heavy orange peel just doesn't look good no matter what. If the texture of this orange peel is very fine (ie, the high and low spots are very closely spaced) then the paint is always going to look dull unless you do wet sand. Any chance we can see a picture or two of the finish?
    Soap and water is all you really need. Don't expect to remove 100% of the blue pigment that has been picked up, but you should be able to get most of it out.
    You may be consuming too much product, but we kind of doubt it. In your environment it may well be that the paint is very dried out and therefore you need more product in order to avoid having the paint just pull all the moisture out of the product. I've had that happen on badly dried out paint when using M105, and the end result was extreme frustration. I had to move to much wetter, more oily product - M80. It sounds as though in your case the M85 and paint get along OK, but we suspect the paint job isn't the best. Again, pictures will help tremendously. I can also tell you that I recently had the opportunity to work on an old Ferrari that spent the last several years in Kuwait and the paint was horribly cobweb swirled and very hard. And it was single stage. The car was shipped to California to be sold at auction and I was tasked with cleaning it up a bit. Unfortunately I only had 2 hours to work on it so it was quite a challenge. But the desert heat and lack of humidity did some definite damage to this paint, and the car had been beautifully restored just a few years ago. There was a photo album in the back seat documenting the entire restoration process, and the car was immaculate when finished. Then it was shipped to Kuwait and the desert started degrading the paint.
    Only in that it might have made the buffing process more tedious as hot dry air and a hot surface will conspire to dry out the compound. When that happens it becomes gummy and sticky, and can be very difficult to remove or almost impossible to use.
    OK, so where do you go from here? Get us some images if you can, but if the paint job is less than wonderful you may be at an impasse. Sometimes a painter will shoot the paint and call it a day. The peel is so tight and small in texture that reflections lack clarity and definition. While compounding can help to some degree, sometimes wet sanding is almost mandatory. Add to that the drying effects of your environment, the extreme level of cobwebs that have only served to "open" the paint even deeper down, and your expectations may have to be lowered.
    Registered Member juliom2's Avatar
    Aug 2010
    Puerto Rico
    271
    Exclamation Re: Buffing single stage cured paint
    Certified Car Crazy.......
    Good questions asalah!!!
    What a great post and follow up Maestro Stoops......!!!!!
    Aug 2011
    Cairo, Egypt
    52
    7
    OK, thanks everybody for stopping here and trying to help
    Michael, thanks very much for the detailed explanation ! That was really helpful !
    I'll bring you some shots for the car tomorrow to show you the hood after buffing, and maybe one side of the car (left untouched)
    Btw, if it needs wet sanding then I will go for that (I already have meguiar's 1500 & 2500grit sanding papers)
    I'm starting a detailing business soon using Meguiar's products, and I need to prove to myself that I'm capable of covering all what it needs
    I guess that dealing with those dry/cheap paint will be part of my daily job, so I'll need to live with that
    Aug 2011
    Cairo, Egypt
    52
    7
    Adding one crazy info I got today
    I measured the paint thickness for different points in the hood and the top of the car
    The gauge reads and average of 600microns (around 24mils) !!!
    Aug 2011
    Cairo, Egypt
    52
    7
    Here are some shots for my hood
    It has some gloss
    Yet it has much orange peel (though the surface is very smooth, and I really cant feel this peel with my hands)
    Paint is very thick (24mils), and last repainting was done 6 months ago
    Aug 2011
    Cairo, Egypt
    52
    7
    btw, if you say that my paint is too cheap to be restored, I'll accept that
    Trabuco Canyon, CA
    21,324
    1135
    Well, we wouldn't go so far as to say that! Looking at the three images you posted, the first one doesn't look all that bad but as you get in closer the third shot looks more like a painting by Monet than a clear reflection in paint. Overall the paint looks reasonably glossy, but it is so loaded with orange peel as to lose all clarity in the reflections.
    Regarding the overall thickness of the paint on this car, that's obviously down to the previous paint jobs being layered on top of the original rather than stripping the car down fully prior to respray. When measuring paint on a factory paint job we usually see readings in the 4.5 to 6.5 mil range, and can generally assume that 1.5 to 2.5 mils of that is clear coat. But on a respray, unless the painter tells you how much clear he shot, you can't really know for sure.
    Now, if you're comfortable with wet sanding and rotary compounding to subsequently remove the sanding marks, then go for it. We don't recommend this process to complete novices (you'd be shocked at the crazy things some people get themselves into!!) but if you've done it before, and/or you're looking to push your skill set and you don't mind running into potential problems on this car, then this could be a great opportunity. This may have been a low budget paint job, but with proper sanding to remove the orange peel and a follow up compounding, it is very likely that this paint can be made to look outstanding. There are plenty of cases online documenting people who literally repainted their cars with a roller and a couple gallons of Rustoleum, including at least one here on MOL: My "rustoleum $50 roll-on paint job"
    Registered Member zbestwun2001's Avatar
    Aug 2011
    Encino, Ca.
    151
    8
    YOU KNOW YOU'RE A REDNECK....
    Let me share this original paint job I saw being done right here in my own parking look.... Car was black... now being repainted, (cough), white.
  1. Buffing single stage
    By FRAZY_z28 in forum Detailing 101
    Last Post: May 30th, 2009, 07:21 AM
  2. Possible single stage paint
    By jpitt1987 in forum Detailing 101
    Last Post: Aug 1st, 2008, 11:16 AM
  3. Single stage paint
    By SOLDSHORT in forum Detailing 101
    Last Post: May 14th, 2006, 07:02 AM
  4. BC/CC or Single Stage Paint?
    By pool_player21 in forum Detailing 101
    Last Post: Mar 14th, 2006, 08:24 AM
  5. Buffing oxidized white single stage with PC
    By Alfisti in forum Detailing 101
    Last Post: Oct 16th, 2004, 06:36 AM
