I'm starting a new detailing business in Egypt
So I decided to count on Meguiar's product, to gain a quick reputation in the local market here
Started working on my first car yesterday (a friend's silver Aveo), and didnt have a good experience at all
First, for removing cobwebs, I started with #84 with an 8" foam cutting pad @ speed 3.5
The buffer was rotating very slowly as long as it's in contact with the surface... With the very minimum pressure, it stops rotating at all !
I had a hard time trying to finish only the hood with this combination
Now when I moved to the polishing phase (using #83 with an 8" foam polishing pad @ speed 2.5), things were even worse
At lower speeds, the polisher can barely do anything
I checked couple of online forums, they say that 8" pads are too big to keep the polisher rotating at good speed (wonder why they make it from first place?)
So I decided to order some 6.5" pads
However, meguiar's local agent in the middle east said that they dont have any pad sizes other than 8" pads, and that all detailers can do a good job using this size, if they use a stronger polisher !
They say that G200v2 is good for waxing... but for paint defect a more aggressive orbital buffer is needed
Is this really true ?? Or should I order smaller pads from somewhere else ?
