Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 63
Thread: I used swirlX and now my paint looks worse..Advice please?
  1. #21
    Aug 2011
    sacramento california
    35
    Re: I used swirlX and now my paint looks worse..Advice please?
    Heres a pic of the marks now -
  2. #22
    Aug 2011
    35
  3. #23
    Aug 2011
    35
  4. #24
    Aug 2011
    35
    So what should I do now? I got a foam applicator with a grip now...do i apply less product but more force? Now that there is wax on it can I even use the swirlX? Should I use a up down motion instead of circles? Im losing confidence that I can correct this...
  5. #25
    Aug 2011
    wilmington,DE.
    6
    hey zaks z31, first where are you applying your products,indoors or outdoors? it truly makes a difference,because of the temperature of the paint. without access to a buffer is hard when you're applying polishes,because of the speed & effectiveness in the polishing process. i would suggest you use the meguiar's #6 cleaner wax,it also has polish that will help with swirls. however apply enough pressure to rub out the swirls,but be prepared for a long process;because you have to play with it!! goodluck,and hit me back up to let me know how it went.
  6. #26
    Aug 2011
    35
    I applied the products as the sun was going down in the shade and the paint was cool to the touch..Im just not sure if any of this stuff will work for this paint or if I should apply more pressure with less product or what..
  7. #27
    32
    18,113
    220
    Dont want less product, the product has the abrasives to remove swirls, scratches, etc.
    Are you able to remove the worst marks if you apply more pressure? (keeping it even of course)
  8. #28
    Aug 2011
    35
    Im going to work on one pretty small area and see..How much pressure should I apply and how much swirlX should I put on the pad? Also should I go in a up and down motion or circles?
  9. #29
    Detail Enthusiast imz4n's Avatar
    Dec 2006
    Orange County, Ca.
    338
    The only place I use terry cloth of any kind is on the rims and when I treat the leather seats. Use the foam pads and the surface should always be cool, heat from the sun or engine causes the product to dry and is not giving you 100% of what the product is capable of. Work in small areas, if the defects in the paint is not gone, stop and try again. Correct the defects before moving on.
    BMW ZSCCA Area Rep SoCal
  10. #30
    32
    18,113
    220
    I would apply a little pressure... then a bit more... then bit more. Check each time, see if things are better or worse or same.
    The direction wont matter.... sometimes can apply more pressure in a straight line.
  1. SwirlX - As a paint cleaner as well?
    By stormtrooper in forum Detailing 101
    Last Post: Mar 15th, 2011, 07:54 AM
  2. Color-X made my paint look worse?
    By Durango in forum Detailing 101
    Last Post: Jun 26th, 2009, 11:43 PM
  3. SwirlX advice / info
    By 6mungo6 in forum Consumer Line
    Last Post: Mar 14th, 2009, 02:30 PM
  4. color x made paint worse
    By vroom in forum Detailing 101
    Last Post: Apr 24th, 2007, 09:31 AM
  5. Black 240sx - Worse condition paint I've ever seen
    By m3tal in forum Show Off Your Latest Detail Work
    Last Post: Oct 23rd, 2006, 06:25 PM
