Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 63
Thread: I used swirlX and now my paint looks worse..Advice please?
  1. #11
    Aug 2011
    sacramento california
    35
    Re: I used swirlX and now my paint looks worse..Advice please?
    Sounds good..i just really know what product is good to fix the further damage I have caused on this crappy black maaco paint..so more opinions are welcome
  2. #12
    32
    18,003
    219
    Probably wont be able to get a definate answer... might take a few test spots too see what works best.
    Be sure to do test spots/areas.... dont do the whole car, then stand back and look.
  3. #13
    Trabuco Canyon, CA
    15,666
    1073
    In the first picture you have very definite tell tales of finger pressure from an aggressive applicator on delicate paint. Terry cloth can be very aggressive, and delicate black paint won't let you get away with that. Read through The Challenge of Delicate Paint for some pointers on how to best deal with this paint. The choice of SwirlX is probably fine, but you need a less aggressive applicator and probably a slight tweak in your application process as well. Delicate paint can be tricky at first, but once you get a process dialed in it's actually very easy to work with.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
  4. #14
    Aug 2011
    35
    Ok I used a little colorX on the left side of the hood..It defiantly brought a shine but I can still see those little white smudge marks..Im using a foam pad this time..Should I use more swirl x first then color x? Let me know please.. Heres a pic..you can see the white smudges near the reflection of the house windows..
  5. #15
    32
    18,003
    219
    May need to do some test spots as mentioned.
    It is possible you would SwirlX gently to remove the worst, and leave a little haze. Then ColorX to remove the haze... but have to experiment on what works best.
  6. #16
    Aug 2011
    35
    Well the sun was going down but it looked like I was getting somewhere..heres a pic using swirlX again followed by ColorX and hitting with yellow wax#26 for good measure..Using a foam applicator this time..
  7. #17
    Aug 2011
    35
  8. #18
    32
    18,003
    219
    Sounds good... give it a good look in the sun tomorrow, and double check. Hopefully all will be well, and you can repeat over the whole car.
  9. #19
    Trabuco Canyon, CA
    15,666
    1073
    Quote Originally Posted by ZaksZ31 View Post
    Looks like you're definitely on the right track, with maybe just a minor hiccup. Going straight to ColorX, as you discovered, only remedied the situation to a small degree. That's because the marks you left in the paint with SwirlX/terry applicator were just deep enough that the very mild cleaning ability of ColorX couldn't quite get rid of them. Plus, being a cleaner wax, ColorX was most likely doing a combination of diminishing the marks and hiding the remnants. By going back over the area with SwirlX but a less aggressive applicator, in this case foam, you're letting the cutting ability of SwirlX do the work without having the negative effects of the terry cloth. While this can still sometimes leave a bit of haze in really delicate paint, ColorX should take care of that. But even with SwirlX and a foam applicator, if you use your fingertips and bare down on the surface it's still possible to create the type of marks you did the first time around. But it looks like you're getting your technique dialed in and making real progress here, so keep it up!
  10. #20
    Aug 2011
    35
    Well I looked in the sun and theres still some marks but not in finger print form anymore lol..Am I applyimg to much palm pressure? Maybe I used to much product? Ill attach a picture
  1. SwirlX - As a paint cleaner as well?
    By stormtrooper in forum Detailing 101
    Last Post: Mar 15th, 2011, 07:54 AM
  2. Color-X made my paint look worse?
    By Durango in forum Detailing 101
    Last Post: Jun 26th, 2009, 11:43 PM
  3. SwirlX advice / info
    By 6mungo6 in forum Consumer Line
    Last Post: Mar 14th, 2009, 02:30 PM
  4. color x made paint worse
    By vroom in forum Detailing 101
    Last Post: Apr 24th, 2007, 09:31 AM
  5. Black 240sx - Worse condition paint I've ever seen
    By m3tal in forum Show Off Your Latest Detail Work
    Last Post: Oct 23rd, 2006, 06:25 PM
