Page 1 of 7 1234567 LastLast
Results 1 to 10 of 63
Thread: I used swirlX and now my paint looks worse..Advice please?
    Aug 2011
    sacramento california
    35
    I have a 1987 nissan pulsar that I got painted a single stage black at macco about 5 months ago..Over time with washing etc I got spider web scratches, swirls, etc. I decided to give my car a full meguiars treatment with a wash, then clay bar, then swirl x and a wax with yellow wax #26 because I heard that is good for black cars..Well everything was fine until I used the swirlx..I used a white applicator pad at first which was made of a terry cloth material I think..That may have been my mistake instead of using a yellow foam one..But then I tried using the product with just microfiber towels and I got the same effect..more swirl marks and I paint holograms..There like a weird white smudge mark..I tried washing and waxing and they wouldn't come off..Any advice? I don't have access to a buffer..Heres a picture:
    Aug 2011
    35
    Re: I used swirlX and now my paint looks worse..Advice please?
    And another..You can see a bunch of swirls too...
    32
    18,031
    219
    Re-paints can be very soft...
    How did you apply with the towel? Looks like there are marks from pressure under your fingertips.
    May need to move back to milder products, but also need to look into good aplicators to distribute the pressure.
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    How long were you working the SwirlX against the paint? Did you let it dry?
    Were you working in the sun or shade?
    Aug 2011
    35
    I was working in the shade but also for the sun for a little bit..When I applied with the town I just put some on the cloth and worked it in a circular motion..Most of it disapered but i used a fresh rag to wipe excess off..Would a white terry applicator usually be ok? What product can I use to take all this stuff off? This paint does scratch VERY easy..
    Aug 2011
    35
    I worked the swirl x into the hood for 3-5 mins before I took a separate rag and wiped it down..
    32
    18,031
    219
    Terry has a high chance of leaving marks in many paints, so not really recomended.
    And as yours seems even more sensitive than normal, you are going to have to look for the best quality items to use to apply/remove.
    You also want to read over this:
    http://www.meguiarsonline.com/forums...ght=soft+paint
    I suspect you will need to look into Ult. Polish or ColorX, and the good foam applicators.
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    You might want to go over the paint again with a foam applicator pad and use a little less product if you can see how creamy it is when applying it to the suface.
    It will take a moderate amount of time to fix this by hand, but you never know depending how hard or soft it is.
    Aug 2011
    35
    So it looks like I need to pick up some foam pads with a handle grip for one..And should I give up on swirlx completely or follow it up with some colorX? Do you guys think color x would get rid of that stuff in the pics? Sadly it didnt even seem like the swirlx removed any swirls..Just added what you see in the pics..
    Registered Member Joe Dragon's Avatar
    east of the sun
    292
    5
    This may be a minor point but when working with a foam pad you may want to place the pad a little lower than the first crease below your finger nails toward your palm so that your fingertips do not apply pressure to the pad. In that way you're more likely to distribute the pressure more evenly along the pad rather than just using your fingertips to work the product into the paint. The same idea goes for the wipe-off. Fold your MF towel in quarters then gently remove the product from the paint, moving the towel slowly & turning it into another quadrant when product starts to build up in the fibers. The layered towel will have less pressure on the paint as compared to just laying the towel out flat & rubbing hard.
  1. SwirlX - As a paint cleaner as well?
    By stormtrooper in forum Detailing 101
    Last Post: Mar 15th, 2011, 07:54 AM
  2. Color-X made my paint look worse?
    By Durango in forum Detailing 101
    Last Post: Jun 26th, 2009, 11:43 PM
  3. SwirlX advice / info
    By 6mungo6 in forum Consumer Line
    Last Post: Mar 14th, 2009, 02:30 PM
  4. color x made paint worse
    By vroom in forum Detailing 101
    Last Post: Apr 24th, 2007, 09:31 AM
  5. Black 240sx - Worse condition paint I've ever seen
    By m3tal in forum Show Off Your Latest Detail Work
    Last Post: Oct 23rd, 2006, 06:25 PM
