Best foaming soap.
  • Best foaming soap.
    Just purchased a foamer and was wondering what everyone is using as their foam soap?
    I've read a couple of reviews online but would like to get the opinions and real life experiences from folks on here.
    It should be here today but I can wait a few days. I currently have Hyper Soap and Shampoo plus.
    Any suggestions?
    Brian's Custom Detailing
    Where detail matters.
    www.brianscustomdetailing.com
    Re: Best foaming soap.
    Super soap foams a lot.
    Here's an old thread that talks about the same topic: glimour foam gun.. what soap for most suds?
    Don't ever put gold class or ultimate wash and wax in the foam gun. It's a waste and it doesn't foam well.
    Hope this helps.
      The Super Soap seems like the one most designed for it.
        Based on the various products I've tried in the foam gun, I would rate Super Soap first followed by Hyperwash as a close second and Shampoo Plus as a distant third in terms of foaming ability. As Marc08EX said, don't bother with Gold Class or Ultimate Wash & Wax as you will be disappointed.
        If you're look at it from an economy of use perspective then Hyperwash would come out on top as its 400:1 dilution ratio means it goes a fair bit further than Super Soap and Shampoo Plus (both 128:1).
          I should add that I use the #62, but lots of foam isnt my main concern.
            Super Soap is the only soap we make specifically formulated for use in a low pressure spray such as the Gilmour foam gun and similar.
            We've found Gold Class to actually foam reasonably well, but UW&W was a huge surprise in the foam gun; it generates crazy suds in a bucket so we thought in a foam gun it would be crazy...... but it's not. Still, UW&W in a foam gun probably gets the most out of the wax protection contained in it since you're usually getting a longer dwell time with a foam gun dispensed soap.
              Thank you sir! I had some Hyper soap but I'm going to swing by the warehouse today and pick some up Super Soap along with a few more essentials that I'm running low on in Gallon form! I just got the Gilmore foam gun so I'm excited to play around with it tonight!
                Speaking of Super Soap, is it being discontinued or is it simply not popular? Meg's Direct and AG do not have it, but ADS still does.
                  I believe it is a limited distribution item.
                    I just picked some up today at my local distributor. Going to test out the foamer tonight on the Cadiliac.
                      I have used a bunch of Meg's soaps and like Shampoo plus the best.
                        For a foam gun, super soap.
                          Shampoo Plus & Super Soap for me.
                            Hi what about NXT car wash does it foam well?
                              Reviving an old thread - I don't see Super Soap in the 2012 Catalog. Is it curtains for this one?
