Over the weekend I applied UP and then followed up UW (liquid). It now has a oily film. Is it wax that wasn't wiped off? I wiped it down several times.
UP and UW leaves oily film
Re: UP and UW leaves oily film
Did you wipe the polish off good before applying the wax? When I do UW I do the whole car and let it dry for about 5 minutes, then it comes off very easily...almost as if you're just wiping the car down for it's final wipe.
Originally posted by aonorato View PostDid you wipe the polish off good before applying the wax? When I do UW I do the whole car and let it dry for about 5 minutes, then it comes off very easily...almost as if you're just wiping the car down for it's final wipe.
Originally posted by Murr1525 View PostApplying the wax thick, and extra hunidity, certainly could lead to some streaking.
Usually a wash will take care of things better than just wiping more.
Just a thought, @ TNOG they teach us to fold the micro fiber towel in half and then in half again. By doing this you end up with 8 sides on one towel. Using one side as a wet wipe off and the second side as a final wipe side. When you notice that the wet side is leaving product behind , swap to 2 clean sides by refolding the micro fiber towel. UW needs to dry completely, under certain conditions this may take more than 5 minutes. They tell us to do a swipe to check if the wax is dry or not. Swipe = one finger using a micro fiber towel. The area should wipe clean with no film left behind. The beauty of UW is that you can apply it and go have a beer or dinner and come back an hour later and the product will wipe off with ease, Make sure to use a clean micro fiber towel for each product you are using to keep from have cross contamination between the products.BMW ZSCCA Area Rep SoCal
Originally posted by bottomsup View PostI think it was the humidity. Thinking back, the wax didn't dry like traditional wax. It doesn't hurt to leave it as is right?2017 Subaru WRX Premium - WR Blue
