i think NXT is the most amazing product to date, I seem to keep going out to look at the finish every hour or so after i have applied it and it might be just in my head, but every time i look the finish seems to be better and better, and i alsonotice at least a 25- 40% improvement after the second application, now, this may be in my head but i am amazed, and yes i am car crazy, but Meguiars make it easy to be crazy, thanks a million
NXT Cure Time
Originally posted by fiberrich
I'm wondering what the pro detailers do regarding applying NXT to a customer’s car when they’re "on the clock". Time is money and they certainly can't wait 12-24 hours before applying a second coat.
Since time is of the essence, do the pro detailers just apply 1 coat of NXT or apply 2 coats with more like 10-15 wait time vs. 20 minute? I’m just curious.
Since almost all of my customers get their vehicles detailed at least three to four times a year, they are usually more concerned about the results, rather than how long the product will last.FRANK CANNA
Mirror Finish Detailing
23rd Year 1986-2009
Originally posted by scottlee
i think NXT is the most amazing product to date, I seem to keep going out to look at the finish every hour or so after i have applied it and it might be just in my head, but every time i look the finish seems to be better and better, and i alsonotice at least a 25- 40% improvement after the second application, now, this may be in my head but i am amazed, and yes i am car crazy, but Meguiars make it easy to be crazy, thanks a millionFRANK CANNA
23rd Year 1986-2009
Has anyone compared NXT to Klasse All in One or Sealant Glaze? I've never used the Klasse products, but I've heard they're great. How do they compare to NXT sealant?
I've been using NXT for several months now on my Lincoln LS and it is a wonderful product. Easy to use, and great results.
Whatever the case, if you're pleased with the NXT, why not just stick with it. Of course, comparing products can be fun!Boss_429
We apply the sealant and give it as much time as possible to dry/haze up.
Sometimes this can be an hour or so if we apply the sealant before we detail the interior or as quick as 20 mins if we have to get going.
The great majority of my clients are repeats and we get to see the results of our detailing months later and in all cases the sealant has a nice shine and holds up very well.
I was using Mike Phillips's Swipe Test method to check wax is dry or not, then simply wipe them off.
More time is better...?03 MINI BRG/BLK CVT - SOLD | 08 Black WRX - FAST!
Re: Re: NXT Cure Time
Another thing I notice once in a while at the clinic is for someone who has just applied Tech Wax, or any wax is to continually wipe the surface, you know, they have already removed the wax but they continue to keep wiping and polishing on the finish. This disrupts the polymer coating on the surface. Instead, wipe off the excess and leave it alone. When you continue to wipe the surface before the polymers have fully set-up, you are moving the polymer coating around, potentially moving it off the finish and onto you polishing cloth.
Stop. Let the polymers set up.
Mike
Is there the same possibility of moving the polymer off the surface using the PC with a Ultimate Bonnet for removal?
RamAirV12015 Dodge Charger R/T Scat Pack 392Granite Crystal
2006 GTO Impulse Blue
This may seem like a stupid question BUT...
I have been applying the booster wax right after the Tech Wax. Do I need to do this. My results are great, but am I actually making the Tech Wax less durable by disrupting it so quickly?2007 Honda Odyssey EX-L (RES/NAVI)
1998 BMW 318ti
Hey,
It would be better to allow the NXT Tech Wax time to set up before touching the surface with any QD or even water, if possible.
As for leaving the NXT Tech Wax on longer than recommended, that is a choice the user needs to make. Generally, the time was chosen by the Meguiar's chemists as a reference point to provide the best performance from the product. Sometimes leaving it on too long can cause streaks in some climates. Moreover, not leaving it long enough can cause smears. In the end, I suggest strongly to use Mike's Swipe Test to see when the NXT is ready to be removed. Again, this will generally be between 10-15 minutes.
Tim
Re: Re: Re: NXT Cure Time
RamAirV1
Re: Re: Re: Re: NXT Cure Time
Yes. The same thing applies to machine removal as does to hand removal. Remove the wax then move on, don't continue to run the polisher/bonnet over and over the surface. Let the polymers set-up.
I'm probably better off using the PC for wax removal as the UBs work so well I only make one pass. As far as removal by hand, old habits die hard. I'm glad you pointed that out.
Originally posted by 2hotford
There should be no problem with driving it. It is only a problem if it rains, or if a person uses a QD before the curing is complete.
Rain on NXT Tech Wax
I just waxed the lower half of my truck from the trim line down all the way around and a freak rain shower occurred about an hour after I finished. I do not have a garage that is open at this time. I had polished it with #7 glaze and then waxed with liquid Tech Wax before the shower.
What should my next step be: let everything dry and rewax today or wait until tomorrow and rewax, or not worry about it and rewax the next time I wash the truck.
Suggestions?
Thanks.
I would rewax the next time you wash it. Or wait a couple of week. The rain did not wash the wax away but since it didn't have the time to cure, the durability may not be optimum. But if it was really hot out it may have cured rather quickly.
You may just want to wait and see how long the slickness and gloss lasts and watch the sheeting action when you wash it. When it seems like the wax is gone, then rewax. If that was your first coat apply the second next time you wax.
Just some things to think about.
