Best way to remove haze on inside of windows
Results 1 to 10 of 13
Thread: Best way to remove haze on inside of windows
    I love car care lancergts2011's Avatar
    May 2011
    San Diego, California
    32
    8
    I don't have a problem keeping the outside of the windows clean but I get a thin haze film on the inside of the rear window. I'm not sure if it's caused by the vents blowing (that's what I am thinking) but not sure. It's just a real pain to get back there and try to clean them and when I do I seem to always miss some spots and I only notice it when I'm driving and the sun blares down on the rear window. And that happen a great deal in San Diego, CA. Does anyone know what causes that haze?
    2011 Mitsubishi Lancer GTS, Octane Blue
    Registered Member maxpower's Avatar
    May 2006
    30
    Re: Best way to remove haze on inside of windows
    I have always heard that it is 'outgassing' of all the plastic interior parts
    Registered Member rcktpwrd's Avatar
    Oct 2010
    Raleigh, NC
    293
    the only way I know of is regular cleaning with your favorite glass cleaner...
    I get the same as you with the missed spots here and there, windows look great then you go out and the sun hits it and bam dirty spots!
    1976 Cutlass S
    2001 PT Cruiser
    1990 454SS
    1989
    Suburban
    May 2011
    32
    8
    Quote Originally Posted by rcktpwrd View Post
    Yeah. The spots are a real pain in the arse for sure. I am also curious as to what routines/techniques people use to clean their windows. Dang dirty/streaking spots.
    Oct 2010
    Raleigh, NC
    293
    I know when I was doing cleaning on a more regular basis, weekly or biweekly, the glass was much easier to keep clean. Now that I don't have time to clean the car that often it is much harder to keep the glass as clean...
    1976 Cutlass S
    2001 PT Cruiser
    1990 454SS
    1989
    Suburban
    Dec 2009
    Iowa
    2,630
    38
    Been using one of those "as seen on TV" handles with a microfiber cover to clean the windows, since I can't reach some of them. Works fine with any one of the Meguiar's glass cleaners. I believe I read it first from "Murr" go one direction on the outside and perpendicular to that on the inside to identify which side is streaked. Although, it's not too much of a problem with Meguiar's. I believe Stoner's also makes a fancy handle to reach into the corners too. The handles also seem to give you better leverage when you're in some awkward position crawling around in the car.
    I also read somewhere to be careful of defrosters in windows. Go gently and parallel to the wires. Not sure if that is important, but it's what I try to do to avoid damaging them.
    David
    Registered Member Joe Dragon's Avatar
    Denver foothills
    527
    I use one of those handles, got it at Big Lots for $3. I just put my hack towel on top of the contraption on the end & it works well. There are a couple of informative threads on windows cleaning that can be found by doing a search with the right keywords.
    Registered Member Raykreations's Avatar
    Feb 2010
    Greensburg, PA
    47
    102
    I highly recommend Mineral Spirits (odorless). It breaks down any oily type of funk you have going on. Dab a rag with some and wipe inside the window like you would your fav window cleaner. Then, follow up with your window cleaner of choice. If you're a bit leary of using mineral spirits (which is another name for paint thinner - don't be intimidated), try a small spot first. Not sure if aftermarket window tint would be affected - perhaps other forum members could give their 2ยข.
    Ray...
    Graphic Designer and detail semi-freak!
    Jul 2011
    Selangor Malaysia
    7
    If i'm not mistaken this is due to some temperature difference between inside and outside of the car forming a haze/fog in the rear windows. I have this issue often on one of my cars but on my Forte it doesnt happen so much though. Anyway, standard issue glass cleaners (the spray kind) should do the trick.
    Apr 2007
    US
    1,043
    22
    If it is just road or out gassing haze (and not cigar smoke) I found warm water and a good microfiber cloth to be the best thing. Just wet a cloth, clean the window, and wipe dry with a clean microfiber. Every class cleaner I have EVER used, left streaks. Warm water and a couple of MFs was the simple solution for me.
  1. Using the G-100 to remove swirls, scratches and etchings...
    By Mike Phillips in forum The Dual Action Polisher
    Last Post: Oct 19th, 2009, 02:56 PM
  2. Will #80 remove these swirls? Picture inside...
    By dfw in forum The Dual Action Polisher
    Last Post: Jan 30th, 2008, 07:00 PM
  3. Medium or Heavy cut for Rotary buffer for water stains
    By stikman33 in forum Detailing 101
    Last Post: Nov 27th, 2006, 08:15 AM
  4. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
  5. PC and my head is spinning
    By silence in forum Detailing 101
    Last Post: Jul 7th, 2005, 10:36 AM
