Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing
  • Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing
    We are proud to announce the 3rd of several new Quik Tip Videos for 2011 !
    Quick and Easy Wheel Polishing with Meguiar's Wheel Polishing Kit featuring the DynaCone.
    After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
    _________________
    Polishing your aluminum or chrome wheels can be a dirty, messy and often a time consuming job.
    And sometimes, simply choosing the correct polish to use can add confusion.
    To solve these challenges we've introduced Meguiar's Brilliant Solutions Wheel Polishing Kit.
    This kit eliminates the effort and confusion while creating a mirror like shine quickly and easily on all uncoated, polished or chrome surfaces.
    Start by washing and drying your wheels thoroughly to remove all loose debris.
    Attach the Meguiar's DynaCone Polishing Tool to any drill.
    Apply a small amount of the included Meguiar's All Metal Polish directly to the DynaCone Polishing Tool.
    Begin polishing with a slow speed, and gently work the polish on the surface.
    The unique DynaCone shape allows you to easily work on many different shapes and angles.
    Continue polishing and reapply All Metal Polish as needed for maximum shine.
    Remove any remaining residue using a clean microfiber towel to reveal mirror like results.
    Now that your wheels are like new again, it's time to clean and store your DynaCone Polishing Tool so it's ready for the next use.
    Simply remove the DynaCone Polishing Tool from the drill.
    Apply approximately 1 ounce of the supplied Meguiar's Foam Pad Cleaner directly to the tool, saturating the foam as evenly as possible.
    Submerge the tool in a bucket with approximately 1 gallon of water.
    Begin squeezing and kneading the foam thoroughly to release the oxidation and grime.
    Repeat this process several times until the foam looks like new.
    Finish by rinsing and squeezing the foam with fresh, clean water.
    Towel dry and store in a clean safe cabinet or drawer for the next use.
    Quick and easy wheel polishing each and every time using the Meguiar's Wheel Polishing Kit
    Re: Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing
    That´s great!
    I was wondering if it would be ok to wash the wheels using the Dynacone prior to polishing.
      Wash with the DynaCone? No. Best to stay with either an approriate wheel brush or wash mitt and the appropriate cleaning solution for washing prior to polishing.
        And what is best product to seal or wax to protect the wheels?
          Thanks Michael, didn't want to sound like a noob but it seemed like a good ideia to get rid of some of that gunk before polishing. Now I know better!
          thanks a lot!
            will this Meguiar's Foam Pad Cleaner available to buy separately?
              I have 18 inch alloy wheels that are on my new 2011 Mitsubishi Lancer GTS. What is the best way for me to keep them looking great. The vehicle is garaged so I have just been wiping them down every night with a cloth rag and I use a wheel and tire cleaner on them when I wash the car.
              2011 Mitsubishi Lancer GTS, Octane Blue
                You'll want to at least be using a QD spray, not a dry rag.
                Are they clear coated alloys, or bare metal?
                  Drill speeds vary. What is the recommended RPM range for the Dynacone?
                    For most typical corded drills you can run them wide open for heavy correction. Obviously you'll want to feather the trigger a bit when you first start to avoid slinging the product everywhere, but once it's worked into the foam a bit, running at full speed is usually the way to go. Unfortunately, it's extremely rare to find a drill with actual RPM settings on it so it's darn near impossible for us to state "use XXXX RPM for this polish, XXX1 RPM for another".
                      I was thinking more of a minimum not a maximum. I'm thinking I might prefer the ergonomics of one of my cordless drills that has a top end of 800RPM. If that's not enough then it's not an option. This is the drill:
                      Is 800RPM enough?
