DA MF Correction System - Jet Black BMW X3
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: DA MF Correction System - Jet Black BMW X3
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,888
    66
    Step 1:
    Meguiar's G110v2, Correction Compound D300, 5" microfiber cutting disc DMC5
    DA speed 4, slow arm speed, heavy down pressure, working on small areas at the time, using pad conditioning brush after every section pass, 6 passes per section
    Step 2:
    Meguir's G110v2, Finishing Wax D301, 5" microfiber finishing disc DMF5
    DA speed 3, medium arm speed, medium down pressure, working on small areas at the time, using pad conditioning brush once per panel, 6 passes per section
    Step 3:
    Meguiar's G110v2, Ultimate Wax Paste, 7204 4" black finishing pad
    DA speed 2.5, fast arm speed, 3 passes per section
    Step 4:
    Glass - Glass Cleaner Concentrate D120 10:1,
    Tires - All Purpose Cleaner D101 4:1, Hyper Dressing D170 1:1 High Gloss,
    Wheels - Wheel Brightner D140,
    Exterior Trim - Hyper Dressing D170 3:1 Satin Finish.
    Final results:
    DA Microfiber Correction System offers great correction ability. D300 has a similar feeling to M105's paint removal but there's no dust and buffing cycle is much longer. D301 finishes surface really nicely. On this paint after Correction Compound I could go straight to a any wax/ sealant. The microfiber discs offer nice cushioning feeling.
    This System is denitely for anybody who's familiar with DA polishers. Following Meguiar's guidance will result in show car shine. D300 really likes down pressure, slow arm speed, frequent disc cleaning and small working areas for maximum defect removal.
    Ultimate Wax is like Next Tech Wax 2.0 on steroids. It darkens paint nicely adding to it depth and high gloss. Wipe on and wipe off are super easy but thin layer is the key.
    Here's my new favorite combo for paint correction projects:
    It was hard to imagine this level of correction possible with dual action polishers but Meguiar's delivered it.
    Registered Member BS MXRacer's Avatar
    Oct 2010
    Fort Collins Colorado
    175
    Re: DA MF Correction System - Jet Black BMW X3
    Nice results!
    Your experience was very similiar to mine; 6 section passes, heavy pressure, and slow arm speed.
    When cleaning the pads with the brush I found it to help to invert the polisher so particles of spent liquid would fall off, what did you do?
    Dec 2009
    Iowa
    2,634
    40
    Greg,
    Thanks for the step by step and super job on the vehicle, looks great.
    Do you feel you saved a great deal of time using the DA MF system over the more traditional method?
    Doing all of your "extra" work at the end, do you worry about overspray and removing the wax you just put on?
    (Thanks for this list, I'm always interested in how folks handle the details of a detail !! Including the dilution rate is helpful too)
    Again, thanks and it looks great.
    David
    Feb 2010
    Suffern, NY
    28
    2,841
    54
    Great job Greg! BMW looks really nice.
    I also found that one of the keys to operating this system successfully is pressure. This system loves pressure.
    By the way, Ultimate Paste Wax is great stuff also!
    Okanagan Valley, BC
    4,544
    393
    Hey Greg,
    The Bimmer turned out great!!! The black is so deep and rich!!!
    I am glad you like the new DA MF System!
    Tim
    BMW Nut smack's Avatar
    May 2010
    Belleville Ill
    963
    19
    Jesus Greg,
    That is amazing. Was there any hazing left behind after the first step? Will have to get this system after my return home.
    2011 Jet Black 328i Touring
    2007 Jet Black 335i Sedan
    Nov 2009
    Brooklyn New York
    2,888
    66
    Quote Originally Posted by BS MXRacer View Post
    Nice results!
    Thank you, Sir.
    I worked on softer paint than you had to deal with on the Audi. But still used pretty hard down pressure in Step 1 with D300.
    I kept my polisher in vertical position while cleaning the disk with pad conditioning brush. You're right, it helped.
    Nov 2009
    Brooklyn New York
    2,888
    66
    Quote Originally Posted by wifpd4 View Post
    Greg,
    Thank you, David.
    I needed 3-4 traditional steps without this System to finish the same way. It's definitely a time saver and a great correction tool.
    Good point on overspray. I used applicators and applied products far away from the vehicle. But if it was a windy day ... you're absolutely right.
    Nov 2009
    Brooklyn New York
    2,888
    66
    Quote Originally Posted by Shawn T. View Post
    Thank you, Shawn.
    You're 100% right about the pressure. But of course you had your hands on The System before me working on the black Pilot.
    I usually use liquid waxes but with Ultimate Wax I switched to the paste version.
    Nov 2009
    Brooklyn New York
    2,888
    66
    Quote Originally Posted by Tim Lingor View Post
    Hey Greg,
    Tim
    Thank you, Tim.
    Your review of The System was the great help indeed. How could I not like it after you gave it two thumbs up.
    Ultimate Wax gave the paint extra darkness and depth on top of D301's richness.
  1. BMW E34 520 : Zero2Hero My 1st attempt on Black by s1tl
    By s1tl in forum Show Off Your Latest Detail Work
    Last Post: Mar 1st, 2011, 07:36 AM
  2. Some work today on a jet black BMW using the MF compounding pad/D300
    By gmblack3 in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Feb 28th, 2011, 03:22 PM
  3. AJ Auto Detail - Black Corvette Correction
    By AjNavo61490 in forum Show Off Your Latest Detail Work
    Last Post: Dec 31st, 2010, 08:01 PM
  4. Mercedes E320CDi Paint Correction Detail (Tuition) - Thin Paint Fun!
    By Kickin Griffin in forum Show Off Your Latest Detail Work
    Last Post: Apr 17th, 2010, 12:30 PM
  5. Apollo Detailing: Full Correction Imola Red '05 BMW 330ci ZHP
    By Holden_Caulfield04 in forum Show Off Your Latest Detail Work
    Last Post: Jun 9th, 2008, 02:37 AM
