Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Dish soaps and car wash products use the same surfactant packages claim
  1. #11
    Registered Member Lasthope05's Avatar
    Oct 2008
    Philadelphia, PA
    191
    7
    Re: Dish soaps and car wash products use the same surfactant packages claim
    I personally dont think dawn is all that agressive as people make it seem. Modern paint does not have oils or need oils to be nourished with and most everybody that used Dawn as a car wash use it to strip waxes/sealants off paint any way.
    I'll tell you what. Using apc and degreasers on rubber and trim pieces is way more harsh than dawn will ever be yet nobody says anything about it drying out rubber/plastic. Go wash your hands with dawn and then with a APC or degreaser and tell me which one dries your hands out more.
    Plus we already use constantly use harsh cleaners on our paint and rubber. Factory wheels are example of this. They are clear coated in the same way cars are and we are all constantly using apc's/degreasers and acids on them. If our paint was or fragile we would be seeing a whole lot of damaged and oxidized wheels.
    Alan T.
  2. #12
    KC thedetailers KC's's Avatar
    Jul 2009
    kuala lumpur Malaysia
    1,558
    518
    Quote Originally Posted by Mary S View Post
    Will you save money? I purchased a gallon of Gold Class Shampoo for about 12 dollars. I don't think Dawn is any cheaper than that.
    very well said
    cheers
    it only takes a little patience and plenty of patience
  3. #13
    Registered Member Mary S's Avatar
    Feb 2010
    Lees Summit, MO
    692
    Quote Originally Posted by Lasthope05 View Post
    True, this is less of an issue with modern clear coat, but not every car that gets washed or detailed has modern clear coat, and while polishes have less of an effect on clear coat, they can make a difference, especially on darker paints and older clear coat and when there is a beginning of clear coat failure.
    Sadly, been there, done that. I once accidentally left an acid wheel cleaner on my husband's clear-coated wheels too long and removed some patches of the clear coat.
  4. #14
    Trabuco Canyon, CA
    15,698
    1073
    Dish detergent is highly effective at stripping grease, and if it strips grease it will strip wax. A quality car wash shampoo won't strip wax. That alone should tell you which product you want to use to wash your car.
    Now, we've said this before and we'll say it again - using dish detergent to wash your car is not going to destroy your paint, plastic, vinyl, rubber, etc if you follow each wash with a full compliment of wax, vinyl and rubber dressing, etc. We've got a forum member who has basically proven this since his father used nothing but dish soap on his car, but otherwise babied the car with very regular surface treatments.
    But the big problem is for the "average" consumer who never does anything more than wash the car - they can't be bothered with any of the "details' of detailing and they won't regularly apply a dressing to the trim, vinyl, etc. Then they wonder why all that trim has turned white in a couple of years. We've seen these cars come into our garage where the plastic cowl is almost white, and it comes from neglect. And neglect isn't just not dressing it, it's using products that can speed up the drying out of the material.
    People think of things like vinyl, leather, paint, etc to be "dry" but in truth they aren't. Unless you let them "dry out". Ever seen a piece of leather that's really "dried out"? Looks a bit different than the seats in your new car, doesn't it? Ever worked on really dried out paint? It pulls the lubricants right out of the paint cleaner or compound you're working on and the product gums up on the surface. Ever try to apply a pure polish to a dried up gel coat? The gel coat color is instantly revitalized, but the pure polish is just soaked up by the finish.
    Paint, and especially gel coat, is actually quite porous and it will take in a bit of these oils. Over time, it can, will and does dry out if not taken care of. There is no doubt that a modern clear coat is far more durable and resilient than earlier single stage lacquer paints, but they are not impervious to the ravages of time and the environment.
    We're huge fans of simply following a "best practices" philosophy when taking car of your car, so we'll finish this the same way we started: Dish detergent is highly effective at stripping grease, and if it strips grease it will strip wax. A quality car wash shampoo won't strip wax. That alone should tell you which product you want to use to wash your car.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
  5. #15
    大家好 Late Bloomer Bunky's Avatar
    Apr 2007
    Raleigh, NC
    423
    Quote Originally Posted by TOGWT View Post
    The MSDS indicates that this product contains sodium hydroxide; these salt crystals could be mildly abrasive when they 'come out' of the compound later and will then permeate the pant surface. Salt is hygroscopic and highly alkaline, the same ingredient are used in engine degreasers to chemically ‘burn’ hydrocarbon oils and grease from engine surfaces.
    Sodium hydroxide will severely stain aluminium, magnesium, etc other ingredients and will tend to oxidise the paint system and emulsify, breakdown and leach out oils found in rubber moulding, trim and the paint system, which causes the plasticizers to dry out causing them to lose their flexibility and eventually fail
    Generally you should avoid the use of household cleaning products for automotive detailing as they are formulated for an entirely different type of cleaning.
    [Your car surface and the dirt that gets on it are a lot different from the food soils and dishes that dishwashing liquids clean effectively. We don't recommend them for cleaning your car] Proctor and Gamble[/COLOR]
    Jon, I looked at the latest Dawn Dishwashing MSDS sheet at Proctor and Gamble (just google dawn msds) and it has no mention of sodium hydroxide.
    ngredients listed on the product label are: biodegradable surfactants and no phosphate. For Ultra Dawn
    Advanced Power, Vinegar Alternative, and Baking Soda Alternative, ingredients listed on the product label are:
    biodegradable surfactants, enzymes, and no phosphate. For antibacterial hand soaps, active ingredient is triclosan
    at 0.1%. Inactive ingredients for antibacterial hand soaps are listed in the Drug Facts box on back label.
    Hazardous Ingredients as defined by OSHA, 29 CFR 1910.1200. and/or WHMIS under the HPA:
    Chemical Name Common Name CAS No. Composition
    Range
    LD50/LC50
    Ethyl alcohol Ethanol 64-17-5 1-5% LD50 (rabbit, oral)=
    6300 mg/kg
    These substances are listed because in their pure bulk form they meet the OSHA definition of hazardous. Any
    hazards associated with this finished product are listed in Section II of this MSDS.
    Al
    ~ Providing biased opinions
  6. #16
    Jul 2009
    1,558
    518
    thank you! for it says
    it always takes a cobbler to know his tools
  7. #17
    Jul 2009
    1,558
    518
    more reply from the Dr Chemist
    You hit the nail on the head "advertise."
    Depends what sort of sealants they use. Happy to back this up with data from chemical manufacturers too (ie Wacker, highly regarded German manufacturer of silicones).
    You have traditional waxes, and numerous types of silicones. The silicones are the ones that can be designed as detergent resistant. Particularly the "reactive-type" amino-functional silicones. These bond with the surface of your paint and then cross-link with each other too. High detergent resistance!
    With respect to car soaps vs dish soaps: they use a very similar surfactant package and therefore will clean in a very similar manner. If your sealant is detergent resistant then it'll resist dish soap AND car soap. If it's not, then either one will strip it.
    Quote:
    more reply
    Let's kill this myth too: sink detergents are (or at least SHOULD BE) neutral, whereas powder for your dishwashing machine is alkaline. It's a matter of how you get a clean; there is more than one way to skin (clean) a cat.
    One can use alkalinity to 'cut' fats/proteins/etc down (actually, it has a slightly diff effect on proteins, regarding the isoelectric point and increasing solubility, but that doesn't matter) OR one can use surfactants to 'pick up' the soils and solubilise them in water. Look up Micelle on wikipedia; the second graphic should help visualise this.
    Knowing this, and also that you can't put foam-producing surfactants into a closed container with high mechanical action (washing machines, both dish and laundry, and also CIP systems used in the Food & Beverage industry) they needed another solution: surfactants. High alkalinity, which works fantastically, also has the down-side that it works fantastically on flesh... hence a neutral pH (and a surfactant package to compensate) in dish soaps.
    All the sink detergents that I ever designed had a neutral pH, for one simple reason: You're putting your hands into it!!!
    Quote:
    last
    Is it? I've never seen that documented! If you have credible links, then I'd be happy to read them for you and give an opinion. There is always more that I don't know about
    I know it's a potential irritant - but that's the nature of surfactants - due to the fact that it picks up the oils on your skin and 'dries' it out. Any time I've heard of a 'gentle' cleaner for your skin, it'll have a standard surfactant like SLES (sodium laureth sulphate) coupled with a moisturiser or humectant (lanolin, glycerine, etc).
    Dangerous? If it was "documented" to be dangerous, then it wouldn't be used frequently in toothpaste, would it? Chemicals need to be GRAS-listed for that (Generally Recognised As Safe). This is merely my speculation though, so please do send through what you know and I'd be more than happy to read it!
    The other thing I've noticed on the forum is that there appears to be a lot of fear regarding your clear coat. You (the forum, in general) give it far less credit than it deserves. The worst thing for your paint-work, aside for contaminants, is UV-radiation. Yep, sunlight. Ever seen a plastic lawn chair fade over time? A vinyl dash start to crack? UV degradation, plain and simple.
    If I was any good at drawing diagrams with the PC I'd do up an explanation for how the paintwork fades, due to UV degradation, which then causes light scattering - and then how a polish works by abrading your clear coat slightly. (Interestingly enough, it's the same reason that milk is white - 100% scattered light)
    This aside, there is a very good reason we've been using acrylic resins for protective coatings for our cars - they're tough! A detergent is NEVER going to destroy it. Pollution and sunlight will chew through it though. My only concern with mild alkalinity is cutting through the wax coating.
    from another forumer
    Finally, I have scientific data that proves Dawn does not dry out your seals/harm paint
    I've always been able to tell who the "Kool-Aid" drinkers were whenever this subject has been brought up in the past
    i am not sure of this ......but it makes no sense
  8. #18
    Meguiars Indonesia Admin
    May 2011
    Jakarta, Indonesia
    136
    4
    Dish soap strip wax for sure, and meg's prod don't
    i have try it my self
    i use two of my foam app pads, full of thick wax on both of them and let them dry for 2 days ( forgot to clean it ^^ )...
    then i put them in two bucket of water, one of them contain Gold class shampoo, and the other contain dish soap...
    the app pad in "dish soap bucket" clean my app pad in 15 minutes
    and the other app pad in "GC shampoo bucket" still full of wax even after i leave it in the water for half days, try to use my hand to remove the wax, but still nothing happen...well, the dust is gone but the wax still there ...
  1. ColorX on New Car With Clear Coat
    By gwarmbat in forum Detailing 101
    Last Post: Sep 25th, 2006, 07:08 AM
  2. about scratcx #9 and show car glaze
    By hardisk88 in forum Detailing 101
    Last Post: Aug 30th, 2006, 05:56 AM
  3. My Meguiar's Detail Clinic Article was Printed!
    By tekygeek in forum Detailing 101
    Last Post: Nov 28th, 2005, 09:32 PM
  4. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
  5. Too many products, which to use?
    By inscape in forum Detailing 101
    Last Post: May 3rd, 2005, 11:08 AM
